Vacuum Line Inquiry
Old Jul 10, 2019 | 08:43 AM
JeffS's Avatar
Default Vacuum Line Inquiry
Looking to replace a cracked vac line.
Does anyone know the proper term for this? I'm having trouble locating it anywhere.
The rubber at the y has a small hole/crack in it.
Thanks in advance.
Old Jul 10, 2019 | 12:02 PM
dinasrt's Avatar
Default Re: Vacuum Line Inquiry
Vacuum line wye(Y) connector? If you can't get the exact part replacement, I would guess that a same size diameter wye or tee in rubber or even hard plastic would work. You may need to get creative with slightly different diameter rubber vacuum hose to get everything together air tight.
Old Jul 11, 2019 | 05:42 AM
Toolman's Avatar
Here is a Mercedes Y connector on ebay.
https://www.ebay.com/itm/NOS-VACUUM-...4AAOSwMVFXH83T
I noticed 9 have been sold. seems to be a common problem.
Old Jul 11, 2019 | 07:42 AM
JeffS's Avatar
Thanks! Silly me thought it was molded to the line...
Old Jul 11, 2019 | 11:01 AM
dinasrt's Avatar
Good find.
ModlessG
Mar 10, 2025 03:38 PM
KrzyFast
Sep 8, 2010 08:34 AM
Eric
May 29, 2009 01:15 AM
AllEuro
Feb 13, 2009 08:40 AM
jpgp51
Jun 27, 2005 07:29 PM
