Should I replace conductor plate?
Old Jan 27, 2020 | 03:47 PM
NickHawk's Avatar
Default Should I replace conductor plate?
I have an '04 Crossfire with 90,000 miles that just developed a bad leak at the 13 pin connector. I plan on replacing the connector, filter, pan gasket and fluid but should I replace the conductor plate while I'm in there? Just curious about anyone's thoughts on this. Thank you.
Old Jan 29, 2020 | 10:19 PM
SrWilliams's Avatar
Default Re: Should I replace conductor plate?
Yes do it. I have a 2007 Crossfire with 81,000 miles on it and out of nowhere I went into Limp Mode that everyone at some point seems to suffer from. I must have sent 15 threads over a 2 month period trying to learn how to change the conductor plate. And today I can proudly say that I am no longer in limp mode---and that is as of today.
But on second thought if you are not throwing any codes at the two sensors then leave well enough alone until you go into Limp Mode. Its not like you are dropping the tranny and so you have to get everything done while the tranny is down. To change the conductor plate all you have to do is remove the tranny pan and it is right there. And so you can wait until the limp mode rises if it ever does.
Sorry for the duplicity in my answer. But no, why send the close to $200 to get a conductor plate when there is nothing wrong with the one you have. If you go into limp mode, simply drain the tranny oil and remove the tranny pan and you right back there at the conductor plate. Changing it is simple
So save your money for now
Old Jan 29, 2020 | 10:31 PM
philosophico's Avatar
If your not trans is not acting funny there is no reason to change. Do the fluid change and replace the trans connector. I have a 05 srt6 with over 200k and my conductor plate has not been changed since I've own the car. The trans fluid yes and connect pin yes as regular maintenance.
Old Jan 30, 2020 | 07:05 AM
NickHawk's Avatar
Okay. Thanks for the advice!
RKC00
Sep 18, 2017 01:04 AM
Bay Cruise
Dec 31, 2014 12:04 AM
Billy22Bob
Nov 3, 2013 01:37 PM
ericfragola
Sep 25, 2013 06:13 PM
Skippy911
Jul 2, 2013 01:47 PM
