Does this look like an RCM Problem?
Old Feb 27, 2020 | 09:28 PM
Enmanuel09's Avatar
Default Does this look like an RCM Problem?
Hi everyone. First off I wanna say your input and advice over the last couple year has been helpful. Recently I experienced my car dying while slowing down, had to wait for it to cool down and it’d start right back up. No codes and given The camshaft sensor had never been replaced, did so and since then it died on me only once. But now at first try when turning it on,it stalls and backfires (I hear it by the exhaust) but will always start right back up. Checked all fuses and decided to take a look at the RCM module. I’m not much of a solder guy but the last connection seems a bit burnt. (Corresponds to air pump relay ). Any help would be appreciated!
Old Feb 27, 2020 | 11:04 PM
Default Re: Does this look like an RCM Problem?
Why change the camshaft sensor, they hardly ever fail. You must use a Bosch part as the others cause trouble.
Did you check for any trouble codes?
Old Feb 28, 2020 | 06:20 AM
Enmanuel09's Avatar
I got caught up reading about how camshaft sensors control the amount of fuel the engine gets and since it’s right there atop I gave it a try. I actually just grabbed one from Oreilly non OEM so I think you’re right with getting the Bosch one. Yes I had my mechanic scan the car with one of those expensive scanners. Unfortunately no codes or lights. Car has 94k. Dealer wants to charge 225$ for diAgnose
Old Feb 28, 2020 | 10:08 AM
It looks and sounds like the RCM. Install a new one and send your old one to the gentleman on this forum that rebuilds them and keep it with you as a spare.
Old Feb 28, 2020 | 12:32 PM
Enmanuel09's Avatar
That sounds like a good option! Do you know the part number for the RCM?
Old Feb 28, 2020 | 01:59 PM
The Crossfire number is A 170 545 05 05 however the same part is used in the Mercedes. Needwings and FPEURO sells them and also Ebay.
Old Feb 28, 2020 | 05:39 PM
tighed1's Avatar
I refurbish the relay control module. Save some $$!
Email me at
tighed1@hotmail.com for details.
Old Feb 29, 2020 | 02:11 AM
Enmanuel09's Avatar
thank you sir!
Old Feb 29, 2020 | 08:11 AM
cowancom3's Avatar
Here are a couple links to the RCM..both replacement and oem
Amazon Amazon
https://www.autohausaz.com/pn/MB-1705450305
Old Feb 29, 2020 | 05:29 PM
Amazon isn't the only supplier, and good research can find a better deal. Also, my experience with amazon is that sometimes you get returned or used parts as new. Let the buyer beware!
Old Mar 1, 2020 | 10:39 PM
Hanks's Avatar
I second what Zracer said" It looks and sounds like the RCM. Install a new one and send your old one to the gentleman on this forum that rebuilds them and keep it with you as a spare."
Send it to tighed1 and it will be better than new. his work is better than the factory. if you do you will be happy.
Old Mar 1, 2020 | 11:35 PM
Sussudio's Avatar
Besides OEM, are there any other RCM that are recommended to buy? I’ve seen a couple different brands or companies that sell them. Thank you in advance
velociabstract
Racing
20
Apr 19, 2014 11:08 AM
livefreeordie
51
Oct 11, 2010 01:14 PM
InfernoRedXfire
Other Cars Etc
Oct 8, 2009 10:19 AM
Louie K
Aug 29, 2009 01:37 PM
themann42
Oct 20, 2004 06:31 AM
