Question on changing valve covers 04 XF 6spd
Old Apr 6, 2020 | 12:43 AM
KnightRyder_77's Avatar
Banned
Default Question on changing valve covers 04 XF 6spd
My question is this is my first time changing the valve cover gaskets on a XF. I have a torque set, and a torque wrench. I bought a really nice kit , came with all new gaskets, hoses and gasket maker. Ok actually 2 questions.
Is it better to clean the engine after all is installed and cured to get rid of all the dirt and grease on the engine.
and also please share any tips and advice on how to complete the process thank you inadvance
Old Apr 6, 2020 | 07:35 AM
Default Re: Question on changing valve covers 04 XF 6spd
The definitive thread on that topic is right here:
https://www.crossfireforum.org/forum...over-leak.html
My saga starts at post 218, but if you read the entire thread, you will learn way more.
Lessons learned along the way:
1) Do'nt try to do this in one hour, the only way to do it RIGHT is to take your time.
2) Maxchion's posts are very helpful - at least to me.
3) You need a new bolt set and gasket set (I got mine from Needswings.com) as well as Ultra Black RTV sealant.
4) I used Max's "tongue depresser" technique to apply the RTV and it worked well.
Old Apr 6, 2020 | 01:54 PM
I would clean around the covers before I took anything apart as you do not want crud falling in the engine when the covers are off.
You can either change the small screws on the two little covers with aluminum or stainless steel screws. I would get aluminum screws.
The larger screws are OK for reuse, torque the screws to the recommended settings. The aluminum screws might break if reused.
Do a search on how to do this job.
marksill
Aug 22, 2016 11:25 PM
God_Likes_Tebow
Feb 11, 2013 12:56 AM
04Fire
Nov 11, 2011 01:57 PM
Mr. F
May 16, 2008 05:13 AM
bobo54545
Jan 11, 2008 08:18 AM
