Car stuck in Driv & Neutral!!!
Old Aug 18, 2020 | 04:13 PM
Billster's Avatar
Unhappy Car stuck in Driv & Neutral!!!
My Crossfire is stuck in Drive & Neutral mode only. Was just trying to back out of my drive way and it just got stuck in Drive and will only go to Neutral, no reverse. I took apart the shifter column and arm rest to get more access. Seems like when I touch the selinoid it works
to shift to park and reverse but as soon as I change to drive and the try to go to reverse it locks up again. Can some one help.
Old Aug 30, 2020 | 03:58 PM
eastside08's Avatar
Default Re: Car stuck in Driv & Neutral!!!
This literally just happened to me and I found a fix. Theres a slot below the "D", insert a pencil into it and it should free up the gear selector.
Old Aug 31, 2020 | 05:43 PM
Billster's Avatar
Perfect it worked!!!! Still keeps happening so will keep the pencil handy until I can fix the problem. Now the BAS/ESP light comes on. I checked my computer and need to change the Secondary Air Pump and hopefully that fixes everything. Will keep you posted. Thanks for your help
Old Aug 31, 2020 | 06:00 PM
Why do you have to replace the pump?
Keep the pencil handy then you can draw on past experience. 😉
Old Aug 31, 2020 | 10:03 PM
philosophico's Avatar
Replacing the air pump will not fix the BAS/ESP light, they are 2 entirely separate components. Air pump is an emission control unit, while the BAS/ESP belongs to your traction control system.
Old Aug 31, 2020 | 10:30 PM
Billster's Avatar
Opps forgot to mention I have a error message for the Secondary Air Pump.
Old Sep 1, 2020 | 08:52 AM
Send your RCM to tighed1
( email DJ at tighed1@hotmail.com )
pleasedontsink
Aug 18, 2020 04:33 PM
KDW4Him
21
May 13, 2016 09:47 PM
PA/XFIRE
Dec 29, 2007 11:33 PM
kinkee
May 24, 2007 10:47 AM
diane
70
Dec 26, 2006 10:01 PM
