Hub center rings measure
Old Oct 17, 2020 | 10:43 AM
Astrofriend's Avatar
Default Hub center rings measure
Sometimes when I mount off and on the wheels I afterwards could get vibrations when driving at higher speeds. They are correct balanced and I suspect that the hub center rings are bad or of wrong size.
Some documentation from when I investigated this:
2005 years Chrysler Crossfire: Hub center rings, part 1
Bad center rings can get the wheel a little bit off center and cause vibration at higher speeds.
/Lars
Old Oct 17, 2020 | 12:40 PM
Default Re: Hub center rings measure
/Lars
The photo showing the use of a micrometer used backwards shows why you get a smaller measurement.
The flat part of the micrometer does not touch the curved surface of the wheel bore.
Use a inside micrometer or old fashioned inside callipers and carefully measure them with a vernier.
Old Oct 17, 2020 | 12:47 PM
I wish I had all the tools I need, but living in a flat limits the number of tools.
Still I think this worked fine, the micro meter is not flat at the ends. I got 73.2, 73.1 looks to be a common standard. Ordered new hub center rings this evening.
Lars
Old Jan 5, 2021 | 05:19 PM
That sounds about the same problem as I have. I ordered new Hub Center Rings of correct size, but it failed to be delivered. I tried to found new ones nearby where I live, but instead I got the information that some people 3D pritend them. I have test printed one ring, but it's to cold to do some work on the car now. Look et the bottom of this page and I have collected some information:
/Lars
Old Feb 26, 2021 | 03:18 PM
I got some problem with this. I changed from my earlier 10 mm spacers to 5 mm. These thin spacer didn't have any hub and I have to center them in someway. I had they mounted earlier and then I center them direct with my fingers, the wheel was centered with the ordinary hub ring.
But now when I have my 3D-printer, why not made the hub rings that fit perfect by myselfe ?
Have a look at page three:
But better to buy new ones, I just was curious and wanted to do some test.
Lars
Old Feb 26, 2021 | 11:59 PM
the factory hub is 66.56 that is the OD of the hub,,now you need the Id of the wheel you are installing .
Most of the Mercedes from 1994 to 2011 ,,2011 is where my book stops has the same hub 66.56.
Old Feb 27, 2021 | 09:18 AM
Hi,
Yes this was a bit strange, I saw he diameters: 66.5 mm, 66.6 mm and sometimes the 66.56 mm. I couldn't find out which was correct and I thought that Merecedes who is a Germany company can't used any other than SI units. But now I know, thanks for the help, I have corrected the text on my page.
I also changed the layout a bit to make it easier to moving around the pages.
I have now printed the second hub ring and will go down to the garage and mount it today. Tomorrow a ride out in the sunshine now when the snow is gone. Happy life !
/Lars
/Lars
WindRestrictor
Nov 17, 2016 06:23 PM
mrphotoman
May 30, 2014 11:40 PM
RacingGoddess
Racing
Sep 18, 2009 10:31 AM
maxcichon
Sep 2, 2009 07:53 AM
maxcichon
Dec 3, 2007 11:44 AM
