Coolant light after the crush
Old Feb 2, 2021 | 06:26 AM
kztkadir's Avatar
Default Coolant light after the crush
Hello after a minor crush with my car the coolant light went on. When i have the radiator checked at the service, there is no problem and antifreeze and water full. The service tried to turn the light off but they could not. They checked the cables and the sensor but said there was no fault. They said that under the water tank, the glass water and coolant sensors were working parallel to each other. (After the accident, the water glass warning was not lit.) When the sensors are removed, the glass water light on along with the coolant light. But even though the glass water goes out when they replace the sensor, the coolant never goes out. There is no leakage or water reduction in the water tank. But they still said that the water tank should be dismantled and looked inside. (for sensors i dont know) Has anyone experienced this problem before? I thought the sensors were dislodged because it burned out after the accident but i think i was wrong. Thanks for helps.
Old Feb 2, 2021 | 11:00 AM
Default Re: Coolant light after the crush
If there were sensors in the tank then there would be wires coming from the tank, there are none.
Glass water light? What is that?
Old Feb 2, 2021 | 11:12 AM
Probably means wiper fluid ?
Old Feb 2, 2021 | 11:51 AM
That makes sense.
Old Feb 3, 2021 | 02:35 AM
kztkadir's Avatar
Ah yes wiper fluid. Sorry i didn't know
When the service sensors check, wiper fluid light turns off, but the coolant light does not. We changed cables but same..
They said that the wiper fluid and coolant sensors running in parallel. Could the coolant sensor be out of order after the crush? But if the sensors were running in parallel, wouldn't the wiper fluid light be on ? There is no problem with the radiator.
Ralph289
Jul 26, 2015 12:52 PM
arejohn
Oct 22, 2014 02:27 PM
mdotoli
Dec 7, 2010 03:40 PM
Valk
Apr 11, 2010 11:45 PM
Tazz
Jan 14, 2008 04:54 AM
