Opinions on if I need a new Skreem
Old Apr 6, 2021 | 03:52 PM
SpideyKrist's Avatar
Question Opinions on if I need a new Skreem
Wondering if it's likely both my ignition switch assembly and skreem module died at the same time?
Recently my cars ignition switch was stuck and wouldn't turn. So after reading other threads I decided to buy and install a new ignition switch assembly which came with a new key fob. It all went smoothly. Put everything back together and I moved the old key's circuit board into a new case, added new batteries and it would lock and unlock perfectly. The car started and I was able to reverse it into my driveway. But after turning it off it did the usually skreemy thing. It would turn on for 2 seconds the first two times but the third time it wouldn't cranks at all. It now will only crank for 2 seconds if I remove the negative battery terminal. Did I miss something when installing the new ignition or did my ignition switch and skreem module both crap out at the same time? Please let me know if you have any suggestions. Thanks.
Old Apr 6, 2021 | 04:31 PM
maggy55's Avatar
Default Re: Opinions on if I need a new Skreem
Did you move the little chip from the old fob to the new case ?
Old Apr 6, 2021 | 04:41 PM
Yes. And it works as normal.
Old Apr 6, 2021 | 06:03 PM
Is it possible a wire came loose, especially the one to the antenna ring? Also, if you change the key and screem you also need to change ECU to match. SOS Diagnostics repairs the original screems.
Old Apr 6, 2021 | 06:37 PM
I did remove the cluster to see if it had a loose wire but it was all tight. I may go with "Precision ECU" because it sounds like they can stop this from ever happening again. But I will also get a quote from SOS. Thanks.
Old Apr 6, 2021 | 10:35 PM
If the chip works as normal how come the car does not start ?
I think you are missing out some information.
Old Apr 7, 2021 | 10:59 PM
So I feel stupid, I assumed the transponder chip was soldered onto the fob's circuit board but then realized it was wedged in the corner of the old case. Once I moved that over it works now. Thank you all for helping out.
Old Apr 7, 2021 | 11:34 PM
maggy55's Avatar
That's the chip I was talking about. Glad you figured it out.
Old Apr 8, 2021 | 02:38 AM
Ronman's Avatar
I am glad you didn't throw it away by accident like others have.
wombrat
72
Jan 27, 2025 06:07 PM
Xd9
Aug 9, 2020 05:18 PM
Whitcat9
Feb 28, 2017 06:05 AM
bbrette
Feb 18, 2016 12:59 PM
Selbyl
Jul 31, 2014 06:41 AM
