Source for Brand New Driveshafts (SRT-6 & Limited)
Old May 26, 2021 | 10:07 AM
nemiro's Avatar
Default Source for Brand New Driveshafts (SRT-6 & Limited)
I needed a universal joint replaced in my SRT-6 driveshaft. I did find a joint, and was about to attempt to replace on my own. (I did have a plan on proper centering). However, I decided to call a local driveline place, and they proposed using my driveshaft as a model to build a completely new shaft, with replaceable/greaseable u-joints, new center bearing, boots and flex joints. It turns out, they already had a model for the Limited, and an associated part number. Now, having used my shaft, there is now a part number for an SRT-6, also! No more worrying about u-joint issues, just buy a whole new shaft, and if, in the future the u-joint fails, you can replace it yourself. Here's what you need to know:
Base/Limited (manual or auto): 2891-436N $474.06 (includes new flex discs)
SRT-6: 2891-437N, $540.05 (includes new flex discs)
Replacement u-joints: 1-0153G
Order from:
Panhandle Driveline
3984 Avalon Blvd
Milton, FL 32583
(850) 983-6150
Ask for William, tell him Neil Emiro from ND Performance sent you.
Remember, this is a brand new driveshaft. They will ship it directly to you, and you will NOT need a core, so less downtime for you. Pic of my new driveshaft attached. Notice the snap rings in place for the u-joints
Old May 26, 2021 | 04:43 PM
Default Re: Source for Brand New Driveshafts (SRT-6 & Limited)
GREAT information! Glad you got this set up. I am sure ppl (membership) will source these.
Old May 27, 2021 | 09:06 AM
Ditto that!! Saved this in my file of Crossfire Forum Tech Support.
Old May 27, 2021 | 09:19 AM
zip439's Avatar
After you have run this shaft for a good many miles, please come back and tell us how it has held up or not.
Old May 27, 2021 | 09:26 AM
nemiro's Avatar
Actually, I have had it since January, I just kept forgetting to post up here. So far, so good.
MDK
25
Jan 4, 2023 04:00 PM
Kurtp13
Oct 22, 2018 06:20 PM
proboner
Oct 21, 2017 07:18 PM
MrMoPar
Sep 8, 2016 11:23 AM
xfiresrt605
May 9, 2008 10:03 AM
