Looking for auto electrician... Bulbs blowing and alarm sounding
Old Jun 2, 2021 | 08:10 AM
UKNeil's Avatar
Default Looking for auto electrician... Bulbs blowing and alarm sounding
Can anyone recommend a good auto electrician who could fix my crossfire.
ive already taken it to one in Worcester where i live and not much joy. I have now taken it to Westbury Garage in Shrewsbury who also cant fix it. They sent me the following so im looking for someone hopefully not to far from Worcester that can get it back in shape.
cheers
Neil.
P.s. i know NOTHING about cars at all.
Fault – Bulb warnings & bulbs blowing.
Alarm sounding frequently.
There has been a jumper fuse fitted to the interior fuse box, not sure of the reason why so this needs investigating.
The alarm fault looks like a possible wiring issue or maybe the BCM/UEC modules –
I would suggest a Chrysler main dealer or a decent auto electrician.
Unfortunately neither of the faults are ones we have seen before.
Old Jun 2, 2021 | 08:23 AM
zip439's Avatar
Default Re: Looking for auto electrician... Bulbs blowing and alarm sounding
DO NOT take your car to a Chrysler dealer; Contact the Crossfire club there in England for further guidance.
Old Jun 2, 2021 | 09:18 AM
Doc78's Avatar
cheers
Neil.
Hello,
I completely agree with not taking it to the stealership!
It would help us if you told us what bulbs are blowing. What fuses have a jumper going to them.
The siren going off all the time sounds like a common problem with the sirens on this car. Make a long story short the batteries leak over time and short out the circuit board that they are a part of in the siren. My buddies did the same thing. He unhooked the negative battery terminal and pulled the number 9 fuse under the hood on the passengers side.There should be a card under the lid to tell you which one number nine is. It is usually a 10 AMP Red fuse. The siren has a battery back up so it will go off(very loud!) for awhile till the batteries drain. Then reconnect negative battery cable and he has had no more problems with that.
He also has no mechanical skills so that was his simple solution.
Now my solution if you want to go a little further you will have to unplug the siren located under the front cowl where the windshield wipers are connected. There is a thread here that is great on how to do it. You will need a puller to help take the windshield wipers off. (highly recommended!)
I just did this because my siren was sounding like a cricket on crack as they say here. And mine would go off at the most random times especially when it was hot out! I bought a new siren for mine. I bought my new siren from needswings.
I am also trying to repair mine but it is in pretty bad shape so we will see how that goes but for $11 for the replacement batteries I said i'll give it a shot. The batteries can be found on ebay. If you want the link let me know.
Hope I helped.
P.S> If you go the cowl removal route take the time to clean out the four drainage ports under there there is one on the drivers side one in the middle and two on the passengers side.
Old Jun 8, 2021 | 02:59 PM
magredvet's Avatar
Do the door locks work? First thing they may want to try, is to see if the trunk (boot) is full of water and if the pneumatic pump and connections are submerged. Common problem......................especially in Blighty....................
dre490
Aug 17, 2019 09:07 AM
WingMan
Mar 20, 2017 06:25 PM
Hawkske
Nov 2, 2014 10:01 PM
TIGER
U.K.
15
Aug 21, 2014 02:41 AM
Crossbow34
Aug 10, 2014 09:07 AM
