Crankshaft sensor
Old Jun 12, 2021 | 03:37 AM
grburght's Avatar
Default Crankshaft sensor
Hi there,
It appears that my crankshaft sensor is broken.
Where is the crankshaft sensor located and how do reach that spot to replace the sensor?
Thanks in advance for you help.
Gregor (grburght@ziggo.nl)
Old Jun 12, 2021 | 09:42 AM
Default Re: Crankshaft sensor
Use the search feature at the top of the page.
Old Jun 12, 2021 | 09:47 AM
Doc78's Avatar
Please see link below for PDF that will help you. First is the list of part numbers second is a PDF showing where the sensor is and how to change it.
https://www.crossfireforum.org/forum...parts-list.pdf
https://www.crossfireforum.org/forum...nsor-rev.4.pdf
Hope I helped.
Old Jun 12, 2021 | 10:19 AM
grburght's Avatar
https://www.crossfireforum.org/forum...t-numbers.html
https://www.crossfireforum.org/forum...tionsensor.pdf
Hope I helped.
Thankmyou so much Doc78
gregor
Old Jun 12, 2021 | 02:05 PM
gregor
I found the second site was for the camshaft sensor not the crankshaft sensor and the first site did not work for me.
Why do you think the sensor is not working?
Look in the Engine Electrical section in the red link “Index of Crossfire……... “ in my signature for the instructions.
It is easier to remove the screw before unclipping the connector, do not drop the screw.
Old Jun 12, 2021 | 05:16 PM
philosophico's Avatar
Dont drop the screw indeed. If you do and cant get it, forget it. It will lodge itself in a wedge space against the shield plate backing and its not coming out even with a magnet. You'll be ordering a new screw and waiting a few days for it to arrive like my dumazz.
Old Jun 13, 2021 | 06:39 AM
grburght's Avatar
Thanks for your advice!
Old Jun 13, 2021 | 10:07 AM
Where did you buy the screw?
Old Jun 14, 2021 | 08:52 AM
Doc78's Avatar
I corrected the links my apologizes.
phil alvirez
Jun 13, 2021 01:36 PM
garys383
Aug 14, 2019 06:11 PM
mendezfa
Nov 8, 2014 09:56 PM
Holycrap
Mar 15, 2011 06:06 PM
lannyx
Feb 12, 2011 05:20 AM
