Hooking up horn to aftermarket steering wheel
Old Sep 24, 2021 | 04:47 PM
TheDeer's Avatar
Default Hooking up horn to aftermarket steering wheel
I recently changed out my stock steering wheel with a nrg steering wheel and momo hub, fortunately I was able to find the hub that has the same splines and grooves for the clock spring so I didn't have to modify it at all. My only issue is I can't seem to figure out how to hook the horn up seeing as the crossfire has 2 female connectors and the new steering wheel has 1 male and 1 female. Any thoughts on what I should do?
Old Sep 24, 2021 | 04:53 PM
Default Re: Hooking up horn to aftermarket steering wheel
IF you are sure the two wires you have (one male the other female) activates the horns, then just clip the offending connector and install the correct one that matches up to the steering wheel you installed. Of course this is only IF you are SURE the two wires activate the horns AND the two places they connect to also is the 'switch' for the horns that are hooked up to them. Good luck!
Old Sep 24, 2021 | 05:28 PM
TheDeer's Avatar
Will do! Thank you for the suggestion and ill let you know how it goes.
WD40
Aug 8, 2020 08:28 PM
mandingo_rick
Oct 4, 2015 12:45 PM
johnsrt
May 22, 2012 02:02 PM
steveb8699
Nov 2, 2008 11:06 AM
j-fire
Aug 24, 2008 02:59 PM
