Low on Compression Testing
Old Oct 4, 2021 | 06:21 AM
Fancyface831's Avatar
Default Low on Compression Testing
I have a 2008 Crossfire. Its low on compression on #6 which had the misfire code. What could cause this?
Old Oct 4, 2021 | 07:08 AM
Default Re: Low on Compression Testing
rings, valve seating ( carbon ), bent valve. tiny hole in piston
Old Oct 4, 2021 | 10:25 AM
Burnt valve face, head gasket, cylinder wall scored.
Old Oct 4, 2021 | 04:09 PM
Weak coil, spark plug(s) wires, spark plug(s)...
Start with the low cost items first, easy to move a coil and see if the code moves, same for the wires and plugs Good luck!
Old Oct 4, 2021 | 05:01 PM
It sounded like he did a compression test?
Old Oct 10, 2021 | 05:33 PM
What is the best way to compression test
Old Oct 10, 2021 | 05:36 PM
What kind of engine is in a 2008 Chrysler Crossfire
Old Oct 10, 2021 | 05:51 PM
philosophico's Avatar
Just a standard 3.2 v6. Known as mercedes m112. One of there best v6's ever made. Its basically bulletproof and should go a minimal or over 250k miles if left stock and maintained.
Old Oct 11, 2021 | 10:14 AM
NeedsWings's Avatar
pull off the exhaust manifold and see if the air is leaking out the exhaust port = leaking past the valve due to buildup, i have seen that before
Old Oct 11, 2021 | 06:23 PM
please list the 6 compression readings along with cylinder number.
Old Oct 11, 2021 | 06:28 PM
Reading posts 6 and 7 it sounds like he hasn't done it yet and is not sure what kind of engine he has.
Old Oct 11, 2021 | 06:44 PM
Somewhere near Salinas, Lord, he let that slip away ......
Jocko124
Sep 5, 2015 09:10 PM
dayjor
Nov 29, 2014 10:13 PM
Chris L.
May 12, 2013 09:25 AM
yorktown4
Apr 15, 2012 11:30 PM
DTMenace
Aug 16, 2010 03:44 PM
