Yeah another P0410 problem - Help Needed
Old Oct 26, 2021 | 12:27 PM
DeKalb's Avatar
Default Yeah another P0410 problem - Help Needed
2005 Chrysler Crossfire Roadster Limited ... I have owned the vehicle 2 months and have the P0410 Secondary Air Injection System code after about 2 weeks of owning it. I am looking for suggestions as to what to look at or check next ... …
I have done the following … replaced both right and left Air valves, replaced both O2 sensors, replaced Secondary air pump, verified the little blue check valve is working, checked all the hoses associated with the secondary air system, and had the RCM rebuilt ….. any ideas or suggestions where to look or what to check?
I have read most post and watched most videos on the P0410 error code ... I'm at a loss as to what I do next ... I'm relying on the knowledge base here ... Thank you
Old Oct 26, 2021 | 05:27 PM
Enmanuel09's Avatar
Default Re: Yeah another P0410 problem - Help Needed
I think P0410 can also be related to the EGR Valve, if you checked all connections going to and from it I'd suggest cleaning it. They can get really clogged and mine gave me the P0410. Cleaned it and ran it for a couple weeks after in order to pass SMOG in CA. Worth a try!
Old Oct 26, 2021 | 06:02 PM
DeKalb's Avatar
Thank you for the input, I will check the EGR ... but on a good note, checked things over again and cleared the error code ... started and stopped 3 times and the Check Engine Light did NOT come on ... guessing it took a little time for the computer to accept the rebuilt RCM ...
Old Oct 26, 2021 | 06:56 PM
Ronman's Avatar
Who rebuilt the RCM?
Old Oct 27, 2021 | 06:01 AM
DeKalb's Avatar
Originally Posted by ronman
who rebuilt the rcm?
dj
Old Oct 27, 2021 | 10:31 AM
tighed1's Avatar
Anyone wanting to get their RCM rebuilt, email tighed1@hotmail.com for the details.
I replace relays, redo bad solder joints AND ad the Me So Horny mod (horn works without the key).
Old Oct 27, 2021 | 12:55 PM
DeKalb's Avatar
tighed1 is who did mine ... he is very good and quick turn around ... 7 more restarts today and NO Check Engine Light ... very pleased with the rebuild and DJ
Old Oct 27, 2021 | 01:26 PM
dj
DJ OFCOURSE why would you ask, when we all know DL (TIGHED1) is the ONLY person/place to get your RCM repaired. jim
Old Oct 27, 2021 | 02:16 PM
Ronman's Avatar
dj
DJ OFCOURSE why wouls you ask, when we all know DL (TIGHED1) is the ONLY person/place to get your TCM repaired. jim
I was making sure they used him because some people try to do it themselves!
Old Oct 27, 2021 | 02:28 PM
There is nothing wrong with doing it yourself if you have the expertise and equipment available.
Removing the solenoids is tricky if you do not know how, and reflowing the solder at the dry joints can be tricky as well if you do not clean the posts.
The correct size iron of the correct wattage, solder sucker or wick and the correct solder are essential. The solenoids are not that hard to get either.
As I always say ‘How hard can it be?’
Old Oct 27, 2021 | 04:22 PM
I also tried to do one abour 6 to 8 years ago no more all go to DJ for his magic touch.
Old Apr 4, 2022 | 06:40 PM
cmaefs's Avatar
Lightbulb Re: Yeah another P0410 problem - Help Needed
I have had this error for a while. I went to my Chrysler Dealer, and they no longer have trained mechanics for the Crossfire. I went to Mercedees, and they told me to go away (I still have the email). bastards. So I decided to do it my self. I went to Army Moter Officer School in 1977 so I am not by any means a knowledgeable mechanic. I bought a PDF copy of the shop manual from eManualonline for $27 US I went and bought the cheapest OBD2 scanner I could find. Amazon had a MOTOPOWER MP69033 for $25 US. I then went through the system as per chapter 9-426 (P0410) Secondary Air Injection System. I checked all the fuses in the relay control module then unseated inspected and reseated all fuses and connections. Power was correct with my multimeter and all the wiring looked good. The air hoses were intact and had no holes or tears. I ordered
Secondary Air Pump 0001403785 Compatible with MercedesBenz C-Class W202 C240 CLK320 CL500 E320 E55 ML430 ML500 S500 AMG from Amazon for $81 US. It looked correct and when I removed the old one and put them side by side they were identical. I mounted it back on the car and reconnected the hose and power connector. Started the car and the check engine was gone. Turned off the car and used the code reader to check codes and they were all gone. I have a NYS inspection this month so I will see how it goes. Total cost to me was around $135 US Which is a very small fraction of what a dealer would get and total time was a little over an hour.
trispeed
Oct 31, 2020 05:55 PM
Mattisonfam
18
Aug 3, 2017 10:59 AM
mwmilk
Oct 29, 2011 03:30 PM
special_kxoxo
Dec 19, 2010 01:17 AM
04chryslr
Jul 31, 2008 11:36 AM
