conductor plate
Old Nov 21, 2021 | 10:13 PM
roychez's Avatar
Default conductor plate
will this work with the crossfire,
Mercedes 722.6 Conductor Plate Transmission Service Kit - OE Supplier 7226CSK
Old Nov 22, 2021 | 08:35 AM
Wadsworth's Avatar
Default Re: conductor plate
Yes, that will work
Old Oct 7, 2022 | 02:05 AM
richb55's Avatar
Question Re: conductor plate
the 7 mm bolt that removes TCM connector will not come out , can I remove valve body
With connector still bolted in ?
Old Oct 10, 2022 | 08:19 AM
zip439's Avatar
NO. How did you proceed?
Old Oct 10, 2022 | 10:50 AM
Wadsworth's Avatar
Take a look at your new connector it is a captured bolt. Once you get the bolt lose all the way, you should be able to pull the connector out.
Old Oct 10, 2022 | 10:51 AM
richb55's Avatar
I have the same issue 😵‍💫 What to do ??
Old Oct 12, 2022 | 10:42 AM
zip439's Avatar
You have a new conductor plate I believe. Look where the plug bolts to the conductor plate. You should see where the new plug that comes with the kit will screw into. and you will notice on the new plug there is only about 1/8 inch of threads that mate with the conductor plate. Use a long nose pliers or better a vise grip pliers and twist and pull at the same time on the 7mm screw head, When it is loose the 7mm will only come out about 1/2". At that point the plug is loose and you pull the plug off of the conductor plate. If you are replacing the old conductor plate it doesn't matter if it gets messed up in removing the plug. It may help if you drain the transmission and wiggle the conductor plate a bit. That may help the threads grab on the 7mm and you can work it out. Good Luck and tell us what worked for you.
Old Feb 18, 2023 | 07:14 PM
richb55's Avatar
bought the kit from needswings ,conductor plAte
fluids & new connector plug , where the 7 mm bolt would not come out due to nut spinning in plastic conductor plate , we just went at connector plug , cut it in half pulled on it ,we got the Remnants of the connector out 7 mm bolt stayed in , with connector out we were able to remove valve body and swap out the conductor plate, everything went smoothly after that I’ll attach a few pics of why the 7 mm bolt would not come out. I suspect previous owner overtightened it
The infamous 7 mm bolt 😳
That brass square is what 7mm bolt screwed into the plastic surrounding it was all chewed up which was why we could not loosen the bolt
Connector removed with stubborn 7 mm still in place
New conductor plate installed ready to go back in 👍
Old Feb 18, 2023 | 08:55 PM
Wadsworth's Avatar
Don't you just love an hour job that turns into major project. When I changed my connector, I spent an 1/2 hour trying to install new connector. Finally put on my reading glasses and realized the threads were not cut properly. Cheap parts!
I am sure this thread will help people in the future.
Old Feb 18, 2023 | 09:12 PM
richb55's Avatar
I had one with no threads , took me a few to figure it out. Dealer exchanged it
roychez
Mar 19, 2021 02:50 PM
Mdcrossfire
Dec 13, 2018 06:35 PM
ericfragola
Sep 25, 2013 06:13 PM
Skippy911
Jul 2, 2013 01:47 PM
jason60050
Jan 10, 2006 07:34 PM
