no start issue
Old Mar 21, 2022 | 01:13 PM
Default no start issue
My Grandsons Crossfire, he is in another state at college, wouldn't start yesterday. It does not crank. Everything else seems to work. Tried a new battery, no change, replaced the RCM, no change. Have not yet replaced the CPS because they don't usually just die, do they? My only other thoughts are the starter or security system. As usual none of the european shops want to work on it. Any suggestions? He is in Tuscon.
Old Mar 21, 2022 | 01:40 PM
Default Re: no start issue
IF the starter does not engage it is:
RCM
Clutch interlock switch
Pulse module
Bad starter (it's never a bad starter)
One thing you can do, yank the pulse module, pry the cover off, press on the starter relay - if the starter does not engage, the starter itself is bad. PERIOD.
Be careful, pressing that relay bypasses EVERYTHING. The starter will engage even with key off if you press on that relay.
Old Mar 21, 2022 | 01:50 PM
Dummy here, where is the pulse module? It doesn't give me anything on search. And thanks for the response.
Old Mar 21, 2022 | 01:53 PM
PS, does the pulse control module send a code?
Old Mar 21, 2022 | 03:47 PM
No, the pulse module is no "smarter" than the RCM.
To get to it, pop the lid off the fuse box shown below.
Cigar Mod 001s
Old Mar 21, 2022 | 03:51 PM
Now,
Unseat the tabs marked with yellow arrows. Pull off the inner 'lid'.
At the left side of the box, pry between the fuse carrier and the front of the box and lift the fuse carrier out, left (front) end first.
(This carrier is what all those fuses are seated in, LOTS of wires underneath, only pull it up as far as you need to, to clear the pulse module.)
The Pulse Module is about where the red box is, part of it hides under the fuse carrier, so ya gotta yank the carrier out.
Pry the cover off the module....
There will be two relays. One switches power to the SRT circulation pump. The other is the starter relay - your car will have both even if it is not an SRT.
I cant remember which is which, but when you move the right one, the starter WILL engage.
Old Mar 21, 2022 | 04:53 PM
Thank you very much, very informative.
Old Mar 21, 2022 | 10:16 PM
Ronman's Avatar
Be extra careful with the connectors when you remove them they are super fragile, I learned that removing one from a salvage vehicle.
Old Apr 22, 2022 | 04:29 PM
woodysr's Avatar
I'm having similar issue with my 05 rdstr. Issue happens sporatically. Everything works, but no starter response with key in start position. Tried it many times, then (45mins of attempts), finally engages and starts. Same day, she died at stoplight, put in neutral, and it engaged and started. Called Chrysler dealer service dept. described issue, they said "bad ignition switch". Not buying that. Suggestions?
MJinks
Dec 17, 2021 07:44 AM
racecar
Sep 14, 2021 05:01 PM
35
May 21, 2014 12:01 AM
nick78ru
Jul 16, 2013 09:22 PM
lonebuilder
Dec 27, 2010 05:07 PM
