Should I do solenoids when doing conductor plate?
Old Apr 20, 2022 | 09:43 AM
JBRDH's Avatar
Default Should I do solenoids when doing conductor plate?
Doing my conductor plate in a couple weeks... should solenoids also be replaced? (05 na , automatic roadster 137k) or is the fail rate low enough to not worry about them?
Old Apr 20, 2022 | 12:44 PM
nemiro's Avatar
Default Re: Should I do solenoids when doing conductor plate?
For general replacement, I wouldn't bother. If you are looking to upgrade performance, then move to the "blue top" solenoids. Cost is in the $360 range for the pair.
Old Apr 20, 2022 | 12:56 PM
JBRDH's Avatar
Thanks... then i wont bother!
Old Apr 20, 2022 | 05:47 PM
CL770's Avatar
The stock "brown top" solenoids are fine for an NA Crossfire, the "blue top" type flow better but you'd also require the pressure control solenoid (PCS) maps in your TCU to be adjusted (ie you'd need a TCU tune). If you fit blue top solenoids and use your stock TCU then the shift pressures will be raised a heap and it will probably feel like the driveline will break as it changes down through the gears, especially 3 to 2 and 2 to 1. Leave the existing solenoids as they are.
Old Apr 20, 2022 | 10:45 PM
nemiro's Avatar
That is the expert talking right there! Andrew has forgotten more about these things than most of us will ever know.
roychez
Feb 18, 2023 09:12 PM
roychez
Mar 19, 2021 02:50 PM
Mdcrossfire
Dec 13, 2018 06:35 PM
ericfragola
Sep 25, 2013 06:13 PM
Skippy911
Jul 2, 2013 01:47 PM
