Very slow acceleration after full pedal depression
Old May 6, 2022 | 05:25 PM
g3air's Avatar
Question Very slow acceleration after full pedal depression
Have seen similar in a couple of threads. After fully depressing the pedal and accelerating, then future acceleration from stops is almost none for quite a few seconds (dangerous). However, restarting the engine eliminates the symptom. Mechanic told me a code indicated accelerator pedal high sensor error (I was too dumb to ask for and write down the code, but I suspect it was P0223). From what I have read in the forums, I might solve the problem by replacing the Pedal Assy (in the parts list for my 2005 Chrysler Roadster partno 05102641AA on figure 14-1110). I found a good
pertaining to the "washer" issue when replacing the Pedal. I also found what appears to be a "reasonably" priced new pedal assy on eBay
Any thoughts as to whether replacing the pedal assy is a good bet to fix the problem? Or perhaps the problem is further upstream?
Thanks for any thoughts. Love this site!
Old May 11, 2022 | 09:00 AM
g3air's Avatar
Default Re: Very slow acceleration after full pedal depression
Well, I had hoped for some replies, but seeing only views, I will go ahead and try replacing the pedal assembly.
Old May 11, 2022 | 10:02 AM
You seem to have answered your own problem in your post, so nobody bothered to answer.
The problem could be in the throttle body though.
Get a code reader, they cab be cheaper than the minimum charge at a garage.
That code is vital when it can be read.
Old May 11, 2022 | 10:12 AM
nemiro's Avatar
Getting a good code reader, designed to work with Mercedes, specifically, will pay dividends for you. The pedals fail fairly often, but before you purchase, you might just try the throttle reset procedure. Long shot as a fix, but the price is right (free).
Old May 11, 2022 | 04:19 PM
g3air's Avatar
Thank you for those replies and suggestions. I am reviewing various code scanners. I have gone ahead and ordered the pedal assembly and will report back when installed. Edit: have purchased an Autel AL619 (probably an overkill for my level)
Old Sep 5, 2022 | 10:30 AM
g3air's Avatar
Whew, finally got the replacement pedal assembly installed and it has solved the problem (at least so far). The washer that they installed at the factory was a monumental ***** to get out. I left it out for the replacement. FYI, the code reader gave no clues as to the problem (at least for me).
Noticed the hood strut cylinder has failed and ordered a replacement via amazon per a recommendation I found on this wonderful site!!
Old Sep 5, 2022 | 11:28 AM
A round magnet with a hole in it makes it easy to get the washer out.
Old Sep 5, 2022 | 11:34 AM
g3air's Avatar
for you, I'm sure, not for me; and finding a round magnet with a hole in it ...., but thanks for the suggestion (but now with no washer, it's no longer an issue). Plus the nut that is provided has a a built in washer
Old Sep 5, 2022 | 12:09 PM
Well, not really easy but easier as I am older than you.
Old Sep 5, 2022 | 12:51 PM
g3air's Avatar
I don't think so unless your profile is out of date
Old Sep 5, 2022 | 12:55 PM
A bit, I'm 78 now.
Old Sep 5, 2022 | 12:59 PM
g3air's Avatar
You win! I turn 78 next month, old guy! Not sure why my age shows as 76
Old Sep 5, 2022 | 01:09 PM
Your profile shows your birthrate as October 3, 1945
Old Sep 5, 2022 | 01:16 PM
g3air's Avatar
OMG, I am younger than I thought! Time to check into the old folks home!
Old Sep 6, 2022 | 01:15 PM
Don't we ALL wish it was that easy! LOL
crazyfred
Apr 28, 2018 01:05 PM
ckovach
Feb 19, 2014 05:44 PM
BibaResto
Nov 30, 2013 10:50 PM
DesertFox
Nov 21, 2009 02:02 AM
blackxfire
Oct 8, 2007 02:54 PM
