Speed sensor
Old Aug 23, 2022 | 02:56 PM
VolkE05's Avatar
Default Speed sensor
I'm looking for Transmission Input Turbine speed sensor and having a hard time to find the correct one. Is there a MB part number or ZF- Bosch one available.
Old Aug 24, 2022 | 07:40 AM
Default Re: Speed sensor
Hello, and welcome to the forum! I've never heard of anyong asking for this part before (since joining in 2009), I'll now do a search. Can I ask why you need the sensor? Maybe someone else has had this issue before (needing this sensor). Please let us know what is happening, and why you think it is the sensor you're looking for. Thank you, and Good Luck!
Old Aug 24, 2022 | 12:30 PM
VolkE05's Avatar
Thank you for the input The car has only 24K miles on. Service engine light came on and OB scanner showed Input Turbine sensor code PO715. I have the 2 big factories service
manuals. Indicating rough shifting sometimes and drive in one gear (D). Transmission has new filter and oil. MB dealer will not help with Chrysler Vin number. So far I have the wrong
sensor. Any help is appreciated.
Old Aug 24, 2022 | 02:50 PM
zip439's Avatar
I do not think the speed sensor is serviced independent from the conductor plate. Generally fixing code P0715 means replacing the transmission conductor plate. You can find more info by using the search box on the forum and entering conductor plate as a search item. The plate can be bought here : conductor plate
Old Aug 25, 2022 | 09:57 AM
Southernscrew's Avatar
Hi, Anyone can correct me but I thought the speed sensors on the wheels fed back to the conductor plate , Is that a possibility?
Ken
Old Aug 25, 2022 | 04:38 PM
zip439's Avatar
Ken
No, the wheel speed sensors feed directly to the CAB, Controller Anti-lock Brake. They do not have anything to do with the transmission conductor plate.
bc75
Jul 2, 2022 08:48 AM
crosscats
Aug 31, 2021 05:21 PM
twanger
Sep 23, 2019 07:43 PM
Tom3120
Oct 24, 2018 09:37 AM
fflores
Jun 11, 2010 07:42 AM
