CHECK ENGINE light
Old Sep 12, 2022 | 04:17 PM
rmusto's Avatar
Default CHECK ENGINE light
Less than 25,000 miles on Crossfire 2008. When I start the car up in the odometer area two wrenches appear and it reads -731. The check engine light came on today and stayed on.
Old Sep 12, 2022 | 04:39 PM
Default Re: CHECK ENGINE light
It means your car is due for a ‘double wrench’ check up. You can do that yourself and reset the readout to 5,000 miles which will disappear and revert to the previous readout.
The CEL, I am not sure if it is connected to the double wrench sign or not. You probably missed the wrenches until the CEL made them catch your eye.
Old Sep 12, 2022 | 04:50 PM
rmusto's Avatar
How would i reset it so the CEL goes out?
Thanks
Old Sep 12, 2022 | 05:34 PM
Thanks
The instructions are on this forum, search using ‘FSS’.
Or use Google ‘Crossfire FSS’.
Old Sep 12, 2022 | 06:26 PM
rmusto's Avatar
Thanks
Old Sep 12, 2022 | 06:56 PM
This should do it:
1. Turn key to the ON/Run position.
2. Within one second press the ****/button twice.
3. The present status for days or distance is displayed. Within 10 seconds turn the key to OFF.
4. Press and hold the ****/button, while turning the key to ON/RUN again. The present status for days or distance is displayed once more. Continue to hold the ****/button.
After approximately 10 seconds, a signal sounds and the display shows 7,000 miles for approximately 10 seconds.
5. Release the ****/button.
Keep in mind, my first Crossfire and my Graphite (both 05s) were easy to reset. My current (07) SE is hard as hell to reset, takes several attempts.
Old Jul 13, 2023 | 11:47 AM
golfcrackerjack's Avatar
What in God's name is the ****/button? Thanks.
I think it's the mileage reset ****/button, no?
FUBU
35
May 21, 2020 08:44 AM
portmoody
Oct 5, 2012 06:34 PM
liv2fish20
South Forum
Aug 14, 2010 08:19 AM
xfireewabeach
Mar 5, 2009 06:24 PM
stlxfire
Jan 8, 2007 07:27 PM
