No Crank / No Start (Not RCM)
Old Nov 11, 2022 | 05:00 PM
UnaidedPizza's Avatar
Default No Crank / No Start (Not RCM)
Hello,
I'm having some trouble with my 05' SRT6 (135k miles). It's stranded in a parking lot currently because it won't crank or start, when I put in the key all the lights on the dash come on, but when turn I turn it to start there is no starter engaging. No engine codes, either.
So far, I have done the following:
- Tried to jumpstart the car
- Taken the battery out and had it tested at Autozone (it's fine)
- Removed the RCM and reflowed the problem areas and checked them with a multimeter
- Bought a new RCM and a spare CPS just in case
- Installed the new RCM
Based on what I have read on here, I think it is an issue with the starter (or its solenoid), or the pulse module. I'm not sure how to test those parts short of just replacing them, and I would really rather not replace the starter in a parking lot. Any other suggestions would be welcome.
Old Nov 11, 2022 | 05:14 PM
Default Re: No Crank / No Start (Not RCM)
Were there any early symptoms or just all at once? You say you bought a new RCM but did you install it? Be sure to check the battewry ground connection.
Old Nov 11, 2022 | 06:09 PM
tighed1's Avatar
Could be the neutral safety switch.
Hold the key in the START position and slowly move the shift lever through the gears. See if that works.
Old Nov 11, 2022 | 06:24 PM
mikemadeit94's Avatar
Originally Posted by UnaidedPizza
Hello,
check my thread! Same type of issue there’s a tutorial on how to diagnose the pcm and trouble shoot a few things
Old Nov 11, 2022 | 06:34 PM
No symptoms before today. The first time I started the engine, it got up to a few hundred rpm and died within a second. Haven't heard the starter since then.
I did install the new RCM, after reflowing didn't change anything.
Ground connection looks clean, as does battery, no corrosion in sight.
Old Nov 11, 2022 | 06:36 PM
Just tried this, but still nothing.
Old Nov 11, 2022 | 07:01 PM
tighed1's Avatar
To check if the starter is good open the Pulse Module and close the starter relay. Stater should turn on.
Old Nov 13, 2022 | 04:30 PM
Okay, this made the starter turn when the key was in the ON position. Does this mean I need a new Pulse Module or can it be repaired?
UPDATE - I read somewhere that putting the key in really fast and trying to start it might work and it did, but then promptly died. This happened a few times before all the lights on the dash went out and I needed to disconnect and reconnect the battery. Starting to think it might be SKREEM or ignition switch, any thoughts?
Old Nov 14, 2022 | 01:34 AM
red_2005_convertible's Avatar
Hi, I have the same problem, no crank, 2005 automatic roadster. I was looking at the wiring diagrams in the service manual and it looks like if the key is in the on position, and you manually close the starter relay, the car should start, run for a few seconds, and die if it really is the SKREEM - if its not the SKREEM, then the car should run until you turn it off. Can anyone confirm that before I or UnaidedPizza try it?
Old Nov 14, 2022 | 09:22 AM
Originally Posted by red_2005_convertible
Hi, I have the same problem, no crank, 2005 automatic roadster. I was looking at the wiring diagrams in the service manual and it looks like if the key is in the on position, and you manually close the starter relay, the car should start, run for a few seconds, and die immediately if it really is the SKREEM.
There, that is essentially correct. If it is not the SKREEM, the car may still die after it runs a few seconds, as in the case of a weak/bad fuel pump or a throttle body that is insane.
The idea of manually closing the starter relay is simply to verify:
THe starter and starter solenoid are OK.
The battery is capable of providing enough current at sufficient voltage to power the starter and turn the engine over.
There is no severe corrosion/resistance in the battery-starter-block to chassis to battery loop.
If closing the starter relay spins the engine, you know you have an ECU or SKREEM or clutch/park/other interlock issue or an RCM issue.
Old Nov 14, 2022 | 10:47 AM
I can hear the fuel pump turning on, but how do I check an "insane" throttle body?
Old Nov 14, 2022 | 07:15 PM
I just had a similar issue as I've stated above, take a look at my thread. The trouble shooting listed there covers everything needed to test the rcm & pcm. I just replaced my starter & after following pizzas suggestions it in fact was that!
Old Nov 26, 2022 | 07:14 PM
SOLVED - I sent my ECU to PrecisionECU and had them do a SKREEM delete, car now starts and runs, but I had to pull the alarm fuse as the sirens goes off while driving now.
Old Nov 27, 2022 | 01:30 AM
JSK's Avatar
JSK
Good news. Thanks for posting the solution.
Old Nov 30, 2022 | 08:23 AM
Viper-666's Avatar
That's because the Skreem also handles the keyless opening of the Crossfire and deactivates the Alarm when you open your Crossfire with the remote of the keyfob.
So I think that you now can't open your Crossfire with the keyfob, or?
Old Dec 4, 2022 | 11:04 AM
Initially I followed their instructions online to not reinstall the SKREEM module, however I tried reinstalling it without the CAN wire attached, and the key fob began working again, as well as stopping the siren issue. So everything is back to normal.
Old Dec 10, 2022 | 12:20 PM
That's excellent news. Thanks for keeping us posted. I think I have to do the same thing. Is the CAN cable the white cable coming from the the SKREEM in the picture on PrecisionECU website? Also, did you send both the ECU and the SKREEM to them? Thanks again for the info.
-Jerry
Old Dec 10, 2022 | 01:09 PM
Yes, that is the CAN cable. The small black cable above it is labelled ANT, which I believe is what allows the key fob to still unlock the car.
Yes, I sent both the ECU and the SKREEM.
Good luck, and FYI be gentle with the old Chrysler plastic in the dash, I broke several places where the screws hold the dash together!
Old Dec 23, 2022 | 10:55 PM
Sorry for belaboring the point, but I haven't been able to get to removing the SKREEM and ECU until tonight. After re-reading all of the posts, before I remove parts I just want to check if my symptoms still indicate a SKREEM problem. About 4 months ago, I pulled into my driveway and turned off the car. The next day I tried to start it, and got no crank - dash lights went on, windows worked, door locks worked, but no crank. After reading some of the suggestions, I left my key in for more than 30 seconds, the fans didn't go on, and still no crank. Tried the quick key thrust, nothing. Disconnected the negative terminal for a day, put the battery on a charger. Connected the battery again, the rear spoiler went up, still no crank. Tried to move the shifter out of park, won't move even with the key in the ON position (is that also a symptom of a bad SKREEM?) and the rear spoiler won't go down even when the key is in the on position. Starter and solenoid are good - jumped the pulse module. I do have rodent problems - the recent issue was they chewed through the windshield washer motor cable, and the reservoir sensors located under the battery (could they have chewed something else that is preventing starting?) I guess it can hurt removing the security program, but if I don't have to spend $450, I don't want to.
Thanks in advance,
-Jerry
Old Dec 24, 2022 | 07:02 AM
Viper-666's Avatar
That all don't sound like a Skreem problem. Because the the car would crank three times and run for seconds. Look at the RCM for bad solder points or defektive fuses. That the spoiler comes up after you charged the batterie could also be a singn that the batterie is dead.
