Gear box repair/replace
Old Nov 26, 2022 | 06:14 PM
CurtCrossfire's Avatar
Default Gear box repair/replace
I’m in the UK, any idea how much it costs to replace a new gearbox or have it repaired?
parts and labour.
2003 auto coupe
thanks
Old Nov 27, 2022 | 09:53 AM
DTMenace's Avatar
Default Re: Gear box repair/replace
parts and labour.
2003 auto coupe
thanks
Curt
It's difficult to provide advice with the limited information you've provided in your post to replace or rebuild the automatic transmission. Who provided you with the diagnosis of your transmission issues? What are the symptom failures that created this failure, mileage, lack of maintenance, abuse by previous owners? This failure is highly unusual in the Crossfire or MB SLK320 for that time period.
Please supply us with the extended details of this failure to respond accordingly.
Regards,
Dennis
DTMenace
Old Nov 27, 2022 | 10:09 AM
Hi DTMMenace, i diagnosed myself as when it changes gears, sometimes it takes way to long and goes up to 4,000+ RPM before it changes even at low speeds, also i plugged in a obd2 reader and its come up with the code P0730 (incorrect gear ratio), im on 80,000 miles and car was service around 120 miles ago, i have no paperwork that the transition fluid has ever been changed but it says in the owners manual that it should be done at 80,000 miles, ive been told to have the transmition fluid change and it may help with the gear ratio/problem but i dont want to pay out for that just to then pay out for a gear box repair, thanks
Old Nov 27, 2022 | 05:34 PM
DTMenace's Avatar
Curt
I would suggest that you take it to an independent Mercedes Benz mechanic in your area for his review of the transmission's issues you've discussed and obtain a professional's diagnosis, as opposed to your "feeling". Your car is 19 years old, with the original transmission fluid and filter, forget about the 80,000 miles on the ODO and NO written maintenance history.
If you don't want to have the transmission fluid and filter changed ($200), then spend the $4,000-$5,000 pounds for a rebuilt transmission with the labor costs.
Good Luck....
Dennis
DTMenace
Old Dec 1, 2022 | 01:20 PM
THETESTER's Avatar
Where are you in the UK?
Old Dec 1, 2022 | 04:53 PM
Southampton
Old Dec 1, 2022 | 06:14 PM
THETESTER's Avatar
Sorry mate, if you had been in the Manchester area I could have given you the details of an Ex Merc mechanic that has looked after a number of Crossfires, mine included.
Jlgo2011
Nov 27, 2016 07:13 PM
UK-SRT6
Apr 17, 2014 08:25 AM
jdebteg
Mar 30, 2014 05:38 PM
GaRDNK
Apr 7, 2013 07:23 PM
ViffeR
Apr 8, 2005 10:00 PM
