Cut wires
Old Apr 18, 2023 | 10:53 AM
MDKEEHN13's Avatar
Default Cut wires
2005 limited roadster I thought my fluid reservoir was leaking. My washer pump isn’t working, nor my low washer fluid icon. I removed the reservoir and replaced the pump. No leaks from reservoir and new pump didn’t work. After removing the battery I found these severed wires. I know this wiring goes to my reservoir and pump and fluid level indicator. I hope these have nothing to do with spoiler or too, or anything else for that matter. Any information is much appreciated.
Also, if there is a way to connect these wires another way to have a functioning washer sprayer.
thanks for your time and help
Same cut wires just a better picture. Since I put a backing behind them
is there ANYONE OUT THERE THAT CAN ANSWER MY QUESTION ABOUT THESE WIRES ?
please help if you can. I’ve searched and searched everywhere for info. And like I’ve said, me trying to follow wiring diagrams, is like trying fly to the moon in a hot air balloon. PS NOT THE ONE BIDEN FINALLY SHOT DOWN AFTER CHINA GATHERED ALL THE INTELLIGENCE THEY NEEDED. 😡
Old Sep 26, 2023 | 06:54 PM
red_2005_convertible's Avatar
Default Re: Cut wires
Hi MDK,
I've had the exact same issue - mice chewing through my wires. Yes, those wires go to the windshield washer pump and washer fluid level sensors. The gray pneumatic line is for the HVAC louver. I reconnected those wires and put a plastic conduit over them. Now my washer sprays again. No low fluid warning light. In my case, the mice only chewed through the wire under the battery and left the rest of the wire alone, so I had enough wire coming out of the large harness that I could use butt connectors to join everything together. I can imagine if the mice chewed the wires back to the harness, it would get really difficult to connect them back together. The big harness I'm talking about is under the control box (looking towards the drivers side from the passenger side by the battery, those wires come out of the harness under the control box). Probably if you feel along that harness, you'll find the place where the wires exited. To fix it, you might have to remove the control box, peel back the cable dressing, and splice some new wire lengths - not hard, just time consuming.
Hope that helps.
-Jerry
Old Sep 26, 2023 | 09:32 PM
MDKEEHN13's Avatar
Originally Posted by red_2005_convertible
Hi MDK,
Hope that helps.
-Jerry
hope this gets to you Jerry.
so thanks so much, I appreciate your info, and time 👍
vaboca
Nov 29, 2020 11:37 AM
Wes__Hutchinson
May 19, 2014 09:05 PM
baddams1
Feb 10, 2014 03:50 PM
tunaglove
May 6, 2012 10:40 AM
Aullios
Detail Shop
Mar 28, 2012 06:28 PM
