Issues with O2 codes
Old Aug 8, 2023 | 12:51 PM
Joeb45's Avatar
Default Issues with O2 codes
Has anyone had to have their ECM reloaded after having all four O2 sensors replaced? I had them replaced to clear the fault code but the CEL light still indicates a problem. Driveability is still excellent
Old Aug 8, 2023 | 02:53 PM
Default re: Issues with O2 codes
No. CHanging the sensors is all you do, once the ECU starts to get good data, the codes will "time out". Give it a chance to go thru a few cycles.
And if the CEL is on, make sure NEW codes have not come up and that the existing codes are gone.
Keep in mind that O2 sensors can cause a CEL and code when:
1) The O2 sensor(s) is bad.
2) The O2 sensor is fine, and is reporting a real issue (like a real lean burn, a rich burn, a cracked exhaust, a secondary air pump that wont shut off, a bad misfire, a bad injector, etc).
THe point is, is the O2 sensor bad and giving bad data, or is the sensor good and reporting a real issue? Just cause you have O2 sensor codes does NOT mean the sensor is bad. And four bad at the same time? That just does not happen.
What codes is it giving you?
MODERATOR NOTE: Thread title edited for clarity.
hemifiedbird
16
Jul 22, 2019 10:24 AM
fire in the hole
May 17, 2017 11:16 PM
jtaylortech3
18
Nov 27, 2015 09:00 AM
2005 Ragtop
Aug 20, 2014 03:38 PM
reni00
Mar 3, 2012 06:05 PM
