Noise/Issues after new wheels
Old Sep 4, 2023 | 04:21 PM
Twieg1235's Avatar
Default Noise/Issues after new wheels
Got new rims for my car, 20’s was doing it in the driveway, got passenger side done than it started to get dark, so I went to move it to the garage, it instantly started make a loud sound in the rearend, I checked nothing was rubbing or hitting. Took the wheels off put it in stands and it still makes the sound, and the axle shafts will stop every so often while on the gas without me getting in the brake. Emptied the diff fluid and I feel like it was low, someone in the forum said it takes 1.6 litters, not that much in there. I spin the driveshaft by hand and I don’t hear anything in the diff, PLEASE HELP
Old Sep 4, 2023 | 05:28 PM
DeKalb's Avatar
Default re: Noise/Issues after new wheels
What year? Base, Limited, SRT6 ? Manual or automatic ???? need more information
Old Sep 4, 2023 | 05:31 PM
Twieg1235's Avatar
2005, limited, manual
Old Sep 4, 2023 | 06:31 PM
Maybe you used wrong length wheel studs and damaged the parking brake hardware.
Old Sep 4, 2023 | 06:34 PM
Twieg1235's Avatar
Maybe you used wrong length wheel studs and damaged parking brake
I used the same ones that were on it before, but I didn’t know that could happen either, how can I find out if I damaged it?
Old Sep 4, 2023 | 08:58 PM
Remove the brake rotor. The brake rotor also has a built in drum for the parking brake shoes. Your new rims may require shorter wheel bolts. Too long of a bolt will interfere with the parking brake.
Old Sep 4, 2023 | 09:01 PM
Twieg1235's Avatar
alright I will give that a shot tomorrow.
Old Sep 4, 2023 | 11:09 PM
Default Mod notes
Moderator Note:
Other thread deleted. Once this issue is resolved, this thread (which does not belong here) will be moved accordingly. I'll leave it here for now, as you seem to be having problems understanding how to post.
Thread title edited.
Old Sep 5, 2023 | 01:41 AM
JSK's Avatar
JSK
Default Re: Noise/Issues after new wheels
Wrong length and maybe wrong style.
Old Sep 5, 2023 | 09:57 AM
This one was not hard to figure out, was it?
Wish it was always this easy.
Old Sep 5, 2023 | 06:47 PM
DeKalb's Avatar
So what did you find? It's always good to let us know results so we all can use the information in the future ... was it the wheel bolts?
Old Sep 5, 2023 | 08:35 PM
Twieg1235's Avatar
sorry guys for the late response long day at work, but it wasn’t the bolts, I gotta replace the differential. The different size rim on each side destroyed the gears. I didn’t think it would do it so fast but it did. It instantly blew it.
Old Sep 6, 2023 | 10:49 AM
Well, if you force the propshaft to turn and not allow the wheels to turn, the weakest link in the chain from piston pins to wheels will fail.
How we know what is the weakest link in THAT chain...................
Mod Note:
Thread moved to proper forum.
Re-direct expires in three days.
Awans
Oct 22, 2021 06:20 PM
hemifiedbird
16
Jul 22, 2019 10:24 AM
jtaylortech3
18
Nov 27, 2015 09:00 AM
vinnys
Jun 29, 2015 09:33 PM
