Camshaft position sensor bolt size
Old Sep 7, 2023 | 03:30 PM
eseel's Avatar
Default Camshaft position sensor bolt size
While replacing the camshaft position sensor I got all the way through the project and sure enough dropped the bolt when trying to get it back in. Of course then it magically disappears totally. Can anyone tell me the exact size I need to order? Is this something I need to go directly through Mercedes for? Really frustrating. This is a five minute job that takes half of a day because of where they decided to put the bolt.
Old Sep 7, 2023 | 04:57 PM
Ronman's Avatar
Default Re: Camshaft position sensor bolt size
Should be Mercedes part number 910142006001
Old Sep 7, 2023 | 05:10 PM
Hope this helps (Mercedes 6x15x1.0mm Torx Bolt for Crankshaft Sensor Genuine Mercedes 910 142 00 60 01 910.142.00.60.01 910142006001 910-142-00-60-01 | Pelican Parts)!
Old Sep 7, 2023 | 05:16 PM
I think you mean CRANKSHAFT sensor. The reason you dropped it is because you did not use my trick.
I could tell, the chance of dropping that damn screw was 99.999999% before I even started the job. Altho I admit, I thought the most likely time to drop it would be during removal.
Old Sep 7, 2023 | 09:09 PM
Ronman's Avatar
Same bolt for camshaft or crankshaft sensor. I use a magnet to pick up the bolt once it is loose.
DanielNTX
343
Feb 14, 2026 08:19 PM
Brady517
Jul 24, 2021 01:38 PM
Crossfire777_
Dec 31, 2015 12:42 AM
oojacoboo
Dec 17, 2010 10:53 PM
Crossfire725
Sep 4, 2010 09:34 AM
