RE: Another Crank no Fire
Old Nov 22, 2023 | 10:56 PM
xeroplasmic's Avatar
Default RE: Another Crank no Fire
Hi there,
Reading about some of the crank no fires, Trying to Narrow it down here, Compression Combustion Spark.
It's really cranking but no combustion and start, one thing I noticed, is that when I have the key just turned on in the ignition, not even trying to start it, i'm getting a super loud buzzing coming from the Fusebox area it sounds like. Could it be possible that theres a Blown fuse for something that's keeping it from starting properly?? I think I saw theres a fuse for the fuel pump I believe, wondering if that might be a place to start?
One thing I noticed yesterday was that - it took about 3 or 4 cycles of trying to crank, and it finally did start and get combustion. But I let it try for maybe 10-14 cycles to try and get it heated up a little bit and see if anything.. no avail.
Old Nov 23, 2023 | 04:25 PM
Default Re: Another Crank no Fire
My guess, the RCM. Just intuition...
Old Nov 23, 2023 | 07:16 PM
tighed1's Avatar
So cranks but won't start. Have you checked for fuel pressure?
Can you hear the fuel pump run for 2 seconds when you first turn the key to the ON position?
Old Nov 23, 2023 | 11:35 PM
mikemadeit94's Avatar
Buzzing you’re hearing is probably a stuck relay, open RCM carefully take apart the relay that looks burnt and sand down to make clean contact
Old Nov 24, 2023 | 12:08 PM
Actually, I wasn't quite sure what it was that I was hearing, but that sounds about right for a sound I hear when I turn the ignition on and comes from roughly where It would be.
Old Nov 24, 2023 | 12:11 PM
I ordered a CPS off of ebay, will wait for that, and then go from there, and probably get a RCM next.
Old Nov 24, 2023 | 12:13 PM
AH interesting point; I did go back in yesterday, checked fuses and put them back in, and the buzzing at least went away; Engine still not starting. I'll look at pulling the relay out tomorrow probably to look for any damage.
Old Nov 24, 2023 | 12:17 PM
Yep, exactly. I don't have a pressure line to check that, but can hear what I believe should be the fuel pump when the key is in the On position. I even have smelled a little gas leading me to believe i am flooding the engine a bit, and the fuel pump is workin alright. Could be wrong, and that might not necessarily mean the pressure itself is okay. Maybe im going the wrong direction, but I saw a CPS on ebay for 40$ so I ordered that already. Think I need to probably get a Pressure line reader?
Old Nov 24, 2023 | 12:51 PM
tighed1's Avatar
Is the Check Engine light on?
Have you check for fault codes? CPS may give P0335 fault. Make sure the replacement CPS is a BOSCH part.
Old Nov 24, 2023 | 12:54 PM
No check engine light, and I only have a cheapo OBD II, no codes. Yep, the replacement is OEM from another Crossfire I believe
Ktm858
Jun 27, 2025 07:33 PM
rdivers
Dec 16, 2023 09:31 AM
No704
24
Oct 22, 2022 02:25 PM
gompang
15
Jul 27, 2019 02:18 PM
jrams500
Jan 14, 2008 09:04 AM
