Are all flex disc's the same?
Old Nov 27, 2023 | 10:59 PM
Default Are all flex disc's the same?
I'm looking to change the flex disc's on my 2006 roadster base manual transmission.
Are there any differences between manual/automatic or anything I should look for when buying them?
Thanks.
Old Nov 28, 2023 | 09:54 PM
Default Re: Are all flex disc's the same?
So many views, so few answers.
Old Nov 29, 2023 | 07:55 PM
Thanks.
The parts list says they are both the same.
Old Nov 29, 2023 | 09:57 PM
their are about ten 10 companys that make flex disk for both srt6 larger than limited and some of the metal bushings
do not fit our drive shaft.. go to Mercedes pay a lot or go to Needswings 2hours befor discount ends. at Needswings and they will fit.
when u tell him the year and transmission. jim
Old Nov 30, 2023 | 01:43 AM
Thank you for your help.
Old Nov 30, 2023 | 01:48 AM
I've already order a pair online. Hopefully they fit. If not than I'll return them and order from Needswings.
Thanks for your help.
Old Nov 30, 2023 | 09:14 AM
with the drive shaft out,, take one of the flexdisk and put it onto the drive shaft ,,, you may have to tap each metal insert ,,, if it goes in all the way flush u r ok,, if you have hammer it on, they are not a good disk
when removing ,, you may need a crow bar or pench bar and pry them off. this is normal jim
ARNOLD
Feb 24, 2023 03:42 PM
amx1397
Dec 31, 2019 11:03 AM
MiamiTVR
Mar 23, 2018 06:20 PM
tedwing
Aug 20, 2007 10:16 AM
Feb 15, 2007 05:49 PM
