ABS ESP lights and front right brake acting up
Old Dec 3, 2023 | 03:43 PM
jtammel's Avatar
Default ABS ESP lights and front right brake acting up
Symptoms: Front right brake started to brake on its own intermittently. ABS & ESP lights were on on the dash. Faint grinding noise can be heard coming from the front.
Cause: Wheel bearing catastrophic failure and seizure that also damaged wheel hub assembly where the bearing is seated.
Fix: New wheel hub assembly and new bearings
Remember to replace those bearings before they fail as it can be costly to replace if wheel hub assembly gets damaged.
stevemccl
U.K.
33
Jul 24, 2023 08:40 AM
Xx_SKATMAN_xX
Aug 5, 2021 12:47 PM
rayludwiczak
Feb 19, 2020 02:18 PM
ShakaShawn
Apr 13, 2015 04:33 PM
onehundred80
60
Feb 28, 2014 09:38 AM
