steering wheel removable
Old Sep 28, 2005 | 02:06 AM
mini_zoom's Avatar
Default steering wheel removable
How do I remove the steering wheel? Is there any precautions?
Thanks!
Old Sep 28, 2005 | 03:14 AM
respdoc's Avatar
Default Re: steering wheel removable
Thanks!
I would think it would be the same as taking off the older SLK's, so I would search some of the MB forums for detailed instructions.
The real question is why?
Old Sep 28, 2005 | 06:36 AM
harry7's Avatar
Dangerous thing to do if you don't have technical knowledge of the air bag system.
Old Sep 28, 2005 | 12:02 PM
C_Plunkett's Avatar
I don't know how to remove the wheel, but I do know that you must disable the air bag first. Remove the negative battery cable and wait several minutes for the system capacitor to discharge before attempting to remove the wheel. Having an air bag go off in your face while removing the wheel would be very dangerous.
Old Sep 28, 2005 | 12:16 PM
mini_zoom's Avatar
The airbag system is what's worries me the most.
Old Sep 28, 2005 | 03:08 PM
HDDP's Avatar
C_Plunkett is correct. remove neg battery cable first... etc... There are specific instructions in the Crossfire Repair Manual... If you are replacing the wheel with an aftermarket wheel, once you remove the squib for the airbag, you will have to use the DRBIII scan tool to turn the airbag warning light off on your dashboard. I can only assume this is why you are wanting to remove the steering wheel...
Old Sep 28, 2005 | 05:11 PM
mini_zoom's Avatar
Actually I just wanted to adjust the steering wheel one notch to the right. Right now it’s off center at the 11’clock position. The car tracks straight on an even road. It’s just annoying to drive it like that. I just wanted to make sure I don't blow myself up.
Old Sep 28, 2005 | 08:01 PM
harry7's Avatar
That can be corrected with a front end alignment.
Old Sep 28, 2005 | 08:11 PM
HDDP's Avatar
Correct Harry... I assumed he was trying to replace the wheel... A good wheel alignment will correct the issue...
Old Sep 28, 2005 | 10:04 PM
mini_zoom's Avatar
ok, I'll will just get a wheel alignment then. Anybody know of a good reliable place that does wheel alignments in Orange Co. Calif.?
thanks!
Old Sep 28, 2005 | 10:51 PM
former NXMX5's Avatar
its a PITA to replace the wheel... one of the first things i tried to do when i got the car was put a MOMO on. firstly you're right, you'll need a DRBIII to reset the airbag light, but it'll come back on once the system realizes there's still no airbag, but i also found out some more pieces of info...
there is a steering wheel angle sensor that is used for both braking assist (BAS) and traction control (ESP). remove the steering wheel and these features are useless. i cant remember if it affects ABS or not.
the steering wheel hub needed to convert to a MOMO is super hard to find. there is a generic Mercedes adapter (6004, IIRC) but it needs to be drilled out to fit correctly.
just FYI --
Old Oct 6, 2005 | 09:25 PM
LordKoo's Avatar
just FYI --
Do you know if SLK32 steering wheel will fit?
Old Oct 7, 2005 | 08:45 AM
i don't know off hand, but i would guess that it would. because its essentially the same car, it has all the safety features built-in, there's no adapter hub, etc... they're not cheap though. my goal was get a wheel with a smaller diameter than stock. good luck!
PNA
Nov 12, 2020 04:44 PM
da pink
Aug 12, 2015 05:20 PM
princepenson
Jul 29, 2015 07:44 AM
2004_
Jul 11, 2015 03:14 PM
Blackout317
Jul 7, 2015 08:38 PM
