0442 code and other issues
Old May 21, 2024 | 04:12 PM
rednrollin's Avatar
Default 0442 code and other issues
Good Morning
I have a 2005 SRT roadster and was drivinr to get it smogged and was a block away when it threw 0442 code. My fan selector switch went out a few days ago. Followed sticky note including checked fuses and replaced the Blower Motor Resistor Regulator still nothing. Also the engine fan started coming on within a couple minutes and stays on.
When it rains it pours!!! any help woul be greatly appreiated.
Old May 21, 2024 | 07:34 PM
Default Re: 0442 code and other issues
Originally Posted by rednrollin
Good Morning
My guess would be the RCM. Especially with the fan coming on. Try turning the car to on (don't start it) wait for 45 seconds and see if the fan runs at high speed. That would indicate a bad RCM.
Another possibility with 0442 code could be the gas cap. Have you fueled up recently?
Old May 22, 2024 | 09:10 AM
rednrollin's Avatar
The fan will not come on period.
Old May 22, 2024 | 09:14 AM
rednrollin's Avatar
Let me clartify. The engine fan comes on shortly after starting the motor. The ac/heater selector fan switch will not come on at all.
Old May 22, 2024 | 11:34 PM
rednrollin's Avatar
any help?""""""""
Old May 22, 2024 | 11:57 PM
Ronman's Avatar
any help?""""""""
It might be your HVAC module (climate control) or it might be the blower resistor you purchased. If it it not a genuine Behr blower motor resistor then they usually do not work or are defective. The one you purchased is a generic one. The Behr one will run you $40 to $50 before tax and shipping.
Old May 23, 2024 | 01:14 AM
Sorry, I misunderstood which fan you were talking about.
As mentioned before the blower resistor might not work, also I saw this thread a while ago about the fan control. I don't know if this is the cause of your problem, but it might lead you in the right direction.
You can check out this thread. A couple of key posts by pizzaguy are #80 and 84. The part he talks about is very inexpensive.
Fan controller
Old May 23, 2024 | 09:46 AM
Good Morning
If your AC is on the engine fan will come on and stay on as long as the AC is being used.
rednrollin
May 21, 2024 03:01 PM
Bob54
Aug 5, 2023 06:08 PM
jasonk931
Mar 25, 2022 06:22 PM
fric8489
Nov 15, 2021 12:37 PM
austinbarrylee
Dec 11, 2013 10:10 AM
