2008 crossfire limited acceleration
Old Jul 6, 2024 | 03:16 AM
juhugi's Avatar
Default 2008 crossfire limited acceleration
Is there anything to make the initial acceleration faster. It feels like the car is a ford model t when trying to get to 45.I do not race I was just wondering if there was something to make the 0-45 faster.
Old Jul 6, 2024 | 08:35 AM
UrbanE's Avatar
Default Re: 2008 crossfire limited acceleration
Lots of posts about:
-Larger throttle body
-Cold air intake
-Flashed ECU
-Programmed TCU
There lots here, put on a set of reading glasses and dig into 20 years of knowledge.
enjoy the ride
Old Jul 6, 2024 | 09:42 AM
Sprint booster.
Old Jul 6, 2024 | 12:14 PM
If you have the Automatic Transmission this simple procedure is likely to give you the improvement you are looking for
Its called a "Throttle Body Reset"
The Throttle is "Drive By Wire" and adapts to your particular driving style.
To do a Throttle Body Reset follow this simple procedure
Keep the key in for the entire process.
1) Turn the key to the on (not start) position, the position just before the starter turns over.
2) Press the gas pedal FIRMLY to the floor with the key in the "on" position.
3) Hold the pedal FIRMLY to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal.
4) Wait 2 minutes for a full reset to occur.
Summary: Key on, pedal down FIRMLY for 5 seconds, key off, pedal up, wait 2 minutes.
If this doesn't work, disconnect your negitive battery cable for 20 minutes.
This will re-set the parameters in the drive-by-wire throttle body
dcskmail
Nov 16, 2019 10:27 PM
jsanford02
Aug 6, 2009 02:57 PM
shapeshifter309
Feb 7, 2009 07:45 PM
Dodgerpro
Dec 18, 2006 09:31 PM
lron58
Dec 29, 2004 02:44 PM
