Part name and gasket
Old Jul 30, 2024 | 05:47 PM
Default Part name and gasket
I hope everyone isn't getting sick of me yet! What is the name of the plastic part that goes between the Throttle Body and the MAF and does anyone know where to get the gasket that goes on the Throttle Body end? The one that is there is getting hard and brittle.
Thanks
Old Jul 31, 2024 | 02:26 AM
Default Re: Part name and gasket
Thanks
Hi ZERACER,
I just changed these not too long ago.
Luckily I keep records of everything! LOL
Here are the parts and numbers that I used:
The hose connector at the top of the intake is the Air Distribution Hose Connector - MB Part# 1120180209.
The 2 gaskets for the MAF Sensor housing are:
Air Mass Housing To Air Mass Sensor Seal, Mercedes-Benz # 1121590080 (93 mm Outer Diameter - 81 mm Inner Diameter). New part number is: 112159008064
Air Mass Sensor Housing To Engine Seal, Mercedes-Benz # 1121590180 (96.5 mm OD - 86 mm ID). New part number is: 112159018064.
These are probably available at your local Mercedes-Benz dealer. Or at NeedsWings.com
Old Jul 31, 2024 | 10:16 AM
NeedsWings's Avatar
all gaskets are available at
https://www.needswings.com/intake-xf?pagesize=96
Old Jul 31, 2024 | 01:42 PM
Rob, didn't you see where I wrote that in my description?
Ok, it was like 2 minutes ago, but I put you in there!
Old Jul 31, 2024 | 04:28 PM
Thanks everyone
Old Jul 31, 2024 | 05:16 PM
NeedsWings's Avatar
sorry i missed it, thank you!
Old Aug 1, 2024 | 09:57 AM
xintersecty's Avatar
Thanks
Did you get the parts and are you getting any closure to fixing your engine issues?
Old Aug 1, 2024 | 02:06 PM
No, one end was blown out of the intake, so I replaced it and the gaskets. It was still backfiring and running rough. I am now replacing the spark plugs, they were worn and black. I,ll update when I get dome. I work very slow at 80 years old.
awesome1
Mar 18, 2017 01:02 PM
gualtira
Sep 24, 2013 09:34 AM
hcarter
Apr 4, 2010 09:50 PM
NeedsWings
Feb 26, 2010 12:08 AM
welder7018
Oct 22, 2009 01:31 AM
