2005 Crossfire -Key will not turn ignition and beeping sound with red blinking light
Old Aug 1, 2024 | 09:46 AM
tdkflorida's Avatar
Default 2005 Crossfire -Key will not turn ignition and beeping sound with red blinking light
After reassembling the instrument panel and was able to start the car with no issue.
However, now the ignition cylinder will not turn with the key, and there is a constant beeping sound with a flashing red light on the center counsel.
This is similar to the sound when the key is inserted into the ignition.
The only way to stop the beeping sound is to remove Fuse #35.
Thanks for your feedback!
Old Aug 1, 2024 | 02:22 PM
DTMenace's Avatar
Default Re: 2005 Crossfire -Key will not turn ignition and beeping sound with red blinking l
tdkflorida
Your scenario has been discussed numerous times over the past 15 years. Click on the link below and watch the YouTube vid on the stick key issue many owners have experienced.
There are also PDF files if you do a search on the forum.
Good Luck,
Dennis
DTMenace
tcar32909
Aug 1, 2024 02:41 PM
jmccaskill
Apr 22, 2015 08:43 PM
pjm30144
Nov 11, 2013 06:24 PM
brewski
Mar 18, 2011 03:40 PM
