Catalytic converter engine performance
Old Aug 9, 2024 | 06:35 PM
FBB's Avatar
FBB
Default Catalytic converter engine performance
Hey all, I have a 2005 srt6 with 2 bad catalytic converters. If I decide on a cat delete (no inspection state) will the check engine light being on affect how the vehicle will perform? Can I just pull a fuse for the code after the delete? I’ve tried googling and browsing the forum but I couldn’t find a definitive answer, thank you for time.
Old Aug 9, 2024 | 08:02 PM
CL770's Avatar
Default Re: Catalytic converter engine performance
Hi, the check engine light will not effect the performance. The proper fix (to get rid of it) is to have the rear 02 sensor diagnostics coded OFF in the ECU. I'm sure someone like Josh at the MSS could do it for you.
Old Aug 9, 2024 | 10:01 PM
gblack32's Avatar
do you know if it’s the primary cats or the secondary?
Old Aug 10, 2024 | 02:23 AM
CL770's Avatar
Only the primary cats are monitored.
Old Aug 10, 2024 | 10:24 AM
You can remove all the cats and get the o2 extenders so the ecu thinks the cats are still there.
Markv
Jan 12, 2014 06:13 PM
Javier Busquets
Feb 14, 2013 01:46 PM
NovaCharged
Dec 21, 2009 11:38 PM
tomtazz
Sep 12, 2009 03:04 PM
X-FIREcmv
Mar 11, 2008 10:10 PM
