Engine Idling
Old Sep 12, 2024 | 10:06 AM
Buzz's Avatar
Default Engine Idling
Recently my 2006 Crossfire Convertible has started having an engine idling problem. The car starts fine, and everything is alright at startup. Once I start driving, the engine does not go back to idle correctly. Even when shifting, the engine will continue at about 1500 RPM while shifting. When I stop the car, it idles between about 1200 and 1600 RPM, for a while, then slowly drops down to its normal 600 to 800 RPM idle. The idle is high enough that in some gears I don't even need my foot on the accelerator for the car to continue going. Eventually, though, the car will drop the RPM to normal. The car drives fine except for this problem. Is this a known problem? Any suggestions?
Old Sep 12, 2024 | 01:22 PM
Default Re: Engine Idling
How many miles and have you scanned for codes? Possibly your MAF sensor.
Old Sep 12, 2024 | 07:56 PM
Buzz's Avatar
Car has 102,000 on it. Have not scanned for any codes.
Old Sep 12, 2024 | 09:14 PM
You can clean the MAF sensor and throttle body:
Here's a video:
Old Sep 14, 2024 | 03:51 PM
Buzz's Avatar
Did the MAF cleaning and the Throttle Body cleaning, but it did not solve the problem. Any other suggestions? Is it computer related?
Old Sep 14, 2024 | 08:51 PM
I would scan it for codes. Autozone, Pep Boys, etc will scan it for you if you don't have a scanner. Put it in as a Mercedes-Benz 2003 SLK 320.
If it's electrical it will show what it is.
OKC-XFR
Aug 4, 2011 10:04 AM
BRappaport
Jun 12, 2011 10:30 AM
BRappaport
Oct 30, 2010 01:03 PM
tnd
Nov 4, 2009 01:42 AM
srjgtott
May 29, 2006 05:25 AM
