Center support with bearing 2004 crossfire
Old Sep 25, 2024 | 10:16 PM
HappyHippy's Avatar
Default Center support with bearing 2004 crossfire
2004 Crossfire...After reading many different posts. I'm pleased to share that I was able to buy the center support / bearing thru Amazon. Took car to a local mechanic and expressed that I watched several videos on this site of how it can be replaced without having to buy a new driveshaft, with only needing to detach and move heat shield forward to remove driveshaft.
They had it done in about an hour and a half at the cost of $135. The support w/bearing thru Amazon was $60. Total about $200.
Old Sep 25, 2024 | 11:57 PM
Default Re: Center support with bearing 2004 crossfire
Did you have them replace the flex discs while they were there?
Old Sep 26, 2024 | 08:38 AM
did they realign the drive shaft as it has alignment notches for balance,,, ?? u may not feel any difference in
the way it rides or drives but it is vibrating . your new bearing it taking it up so you don't feel it .
your support that was in the car had a lot of miles on it, let us know how the new one last, ,
maybe thak your car back where u had the work done ask if they aligned the drive shaft
when they reinstalled it on one side there is single hump or notch ,,, and on the other
\half of the drive shaft there are 2(two) humps/noches ,, align the short shaft to split the 2 notches
I will tyu to post a picture later today .. jim
Old Sep 26, 2024 | 09:58 AM
UrbanE's Avatar
I did not know about the alignment notches. That’s a great piece of information and really great to know.
The images would be amazing.
Old Sep 26, 2024 | 10:39 AM
HappyHippy's Avatar
No. They appeared to be in Good shape.
Old Sep 26, 2024 | 10:45 AM
Here are the notches dis re guard the white dots those were used when i had the u-joint replaced
this is on the short shaft
also you can see they did not have the tool to center the u joint so i told them to use thin washers to center and weld the washer not the u joint
this is the long half of the drive shaft. disregard the white paint ,that is what the shop used to put every thing back to stock configuration
god shot of the notches and the washer welded in
goykgo
19
Jan 28, 2020 11:32 AM
jimcross
Jun 19, 2018 08:20 PM
MrMoPar
Sep 8, 2016 11:23 AM
Bucksnort
Apr 11, 2016 08:36 PM
