She be Hot!
Old Oct 5, 2024 | 05:19 PM
DaveG's Avatar
Default She be Hot!
My 2005 Crossfire started running hot when in traffic. Doesn't matter if the air is on or not. I removed drive belt and checked water-pump. Bearing seemed a bit grainy and not smooth. Ordered a OEM spec pump and thermostat. Flushed system with distilled water and replaced said parts.Now runs a tick cooler at highway speeds but temp gauge wants to jump when navigating the neighborhood. The radiator fan does kick on but seems to be rather anemic....When I exit the car it has that something is hot smell/vibe. Any help to sort this would be appreciated!!
Old Oct 5, 2024 | 05:38 PM
Default Re: She be Hot!
Please only post in one category. You will get the same answers.
Old Oct 5, 2024 | 05:48 PM
Wadsworth's Avatar
Check to see if the thermostat is opening.
Old Oct 6, 2024 | 03:22 PM
zip439's Avatar
Use Go5 anti freeze 50/50 mix.
Replace the top on the reservoir tank.
Is coolant level remaining constant when you check it cold looking down into reservoir tank?
Old Oct 7, 2024 | 09:34 AM
DaveG's Avatar
Yes...seems to be okay...
Thanks
Tom3120
Jan 6, 2019 05:19 PM
alfomichael
Jun 19, 2017 08:41 AM
psgivens
Sep 29, 2010 07:48 PM
BLKFIN
Jul 23, 2007 01:51 PM
