Auto Transmission Drain Plug Allen or Torx
Old Jan 30, 2025 | 11:39 AM
DeKalb's Avatar
Default Auto Transmission Drain Plug Allen or Torx
is the automatic transmission pan drain plug is a 5mm allen or a torx bit? I don't want to use the wrong tool and mess things up.
I understand it takes a good amount of force to break it loose, is this the normal case? Has anyone used a heat gun with good results?
All help is appreciated.
Old Jan 30, 2025 | 03:33 PM
BPCR45-70's Avatar
Default Re: Auto Transmission Drain Plug Allen or Torx
It's a Torx. We just did a trans fluid change. Could not get that drain plug out, even with heat. Tried an impact wrench and that didn't work either. Eventually stripped the inside. Ended up removing the pan to drain everything out. Messy, but we got it done.
Old Jan 30, 2025 | 03:49 PM
DeKalb's Avatar
I haven't started yet but expect the same out come ... not looking forward to the mess
Old Jan 30, 2025 | 04:16 PM
Nelson G's Avatar
Just use a breaker bar so you have more leverage. I was able to loosen the bolt and drain the trans pan before removing it. Sometimes I tighten the bolt and then loosen it. You can also spray some penetrating spray on it and let it do its job.
Old Jan 30, 2025 | 04:58 PM
DeKalb's Avatar
did you use allen or torx bit?
Old Jan 30, 2025 | 06:42 PM
DeKalb's Avatar
Default Re: Auto Transmission Drain Plug Allen or Torx ... Answered
I think I found the answer ... quoted from MB World "On the 722.6 trans, the drain plug has always been an allen. Size of the allen is either 5 or 6 mm."
Thanks all for your input ... seems reasonable using a torx bit is why so many have rounded the inside and not been able to remove the plug
Old Jan 31, 2025 | 10:47 AM
Wadsworth's Avatar
The Allen key does not go in easily and is deep. Make sure the Allen key is fully inserted, or you will strip it even with proper Allen key. It will require a breaker bar to loosen.
Old Jan 31, 2025 | 10:52 AM
DeKalb's Avatar
Thank you for the information ... the more information I have the better ... your help is appreciated
Old Feb 5, 2025 | 06:07 AM
DeKalb's Avatar
Update ... Transmission drain plug is 5mm Allen ... was able to fully seat the allen in the plug and using a 16" breaker bar, that drain plug was not about to give up and break loose ... using heat from a heat gun made no difference ... was not able to get the drain plug out ... next step was to drop the pan and watch the fluid run all over my garage floor ... 5 of the pan bolts easily broke loose, the 6th pan bolt must have been in cahoots with the drain plug ... it was seized and would not move no matter what I did ... retorqued the bolts that did break loose, put away my tools and poured a cup of coffee
I talked with an independent Mercedes shop about 35 mile away ... they assure me they have seen this before and can take care of my problem ... so I will make an appointment and put it into their hands ... all of this just because I was trying to replace a transmission filter at 100k mile service ... I still love these cars
Old Feb 5, 2025 | 06:05 PM
Originally Posted by DeKalb
Update ... Transmission drain plug is 5mm Allen ... was able to fully seat the allen in the plug and using a 16 breaker bar, that drain plug was not about to give up and break loose ... using heat from a heat gun made no difference ... was not able to get the drain plug out ... next step was to drop the pan and watch the fluid run all over my garage floor ... 5 of the pan bolts easily broke loose, the 6th pan bolt must have been in cahoots with the drain plug ... it was seized and would not move no matter what I did ... retorqued the bolts that did break loose, put away my tools and poured a cup of coffee
I give you credit for trying your best. You made a good decision though. I wouldn't want to snap one of those bolts. Then it becomes a real nightmare!
Best of luck to you!
dcskmail
Dec 4, 2019 05:51 PM
Michael M
Jul 31, 2015 11:30 AM
kolevski
18
Oct 12, 2010 08:05 PM
jackei
Jun 11, 2008 10:27 AM
Robertwav1
Nov 4, 2007 07:21 AM
