Convertible motor replacement cost
Old Jun 5, 2025 | 07:55 AM
Striker5's Avatar
Default Convertible motor replacement cost
The motor that extends and retracts the roof is inop, it can only be done manually. I want to either repair it for sale or deduct this from the asking price. Thanks in advance.
Old Jun 5, 2025 | 09:47 AM
Default Re: Convertible motor replacement cost
Is the fluid reservoir full? Does it run?
Old Jun 5, 2025 | 04:49 PM
I can almost promise you it is not that motor. TOp motors that wont run are caused by (in no specific order of frequency):
Bad divider switch
bad "top open" switch
loss of sync due to a low battery or unknown 'glitch'
water damaged CLP/SSM
fluid level so low the motor has been disabled by the PTCM
failure in the BCM
failure in the brake controller or certain wheel speed sensor failures
defective limit switch on the powered wing (base/limited only)
bad trunk latch switch
bad electric trunk lock solenoid
.......... other stuff I cant think of right now
The last three roadster tops I worked on were fine, the CLP/SSM was water damaged in each one of them.
Old Jun 6, 2025 | 10:57 AM
Striker5's Avatar
Thanks for all the info, I'll start trying to narrow it down, much appreciated.
Tfootman
May 11, 2023 09:26 AM
PNA
Oct 30, 2012 10:54 AM
AGeddy
May 25, 2011 09:59 AM
JHM2K
Nov 24, 2010 12:51 PM
