I'm on the clay bar bandwagon
Old Oct 29, 2005 | 03:57 PM
Rabidraider's Avatar
Thumbs up I'm on the clay bar bandwagon
I did my Crossfire last weekend and was very impressed. Today I did my son's 2004 Honda Accord which was very dirty and it also came out great. It even took off road paint. The only thing it couldn't take off was some "artillery mold spots". That stuff can be used to hold space shuttle tiles in place...
My son even said, "thanks dad"...
Old Oct 29, 2005 | 08:22 PM
ben47's Avatar
Default Re: I'm on the clay bar bandwagon
Why isn't your son doing his own car???
Old Oct 30, 2005 | 12:03 PM
Works full time and finishing his Masters at the same time. So I help him out...
Old Oct 31, 2005 | 03:37 PM
Aero Blue's Avatar
Question Re: I'm on the clay bar bandwagon
What brand clay bar did you use?
Old Oct 31, 2005 | 05:23 PM
The Magic Clay bar and spray...
Old Oct 31, 2005 | 09:25 PM
Aero Blue's Avatar
I noticed you use Mequiars Gold Class paste. I used the liquid version in the past and must say it works GREAT on black, but the durability isn't so good. When you done with the GC, step up to Griots "Best of Show" or their "Paint Sealant". This is coming from a guy who was 100% Mequiars from the time I was 18 to about 34, its that good. www.griotsgarage.com
Old Nov 1, 2005 | 07:14 AM
I'll give it a go...thanks.
Old Nov 1, 2005 | 05:33 PM
GoodEnough's Avatar
I just had my Black Dodge Ram with shell painted. The quality is less than marginal & has a dull shine if that (I got what I paid for, but its better than it was).
I received a quote of up to $800 to have it color sanded.
I'd rather use some elbow grease and a clay bar to help it along.
I've used the clay bars in the past to clean paint but not to try to bring up the shine on a dull paint job.
Do you think it would lift the shine at all??? I'm sending the truck down the road soon & would rather not put much more $$$ into it (hence the cheap paint job).
Your experienced input would be greatly appreciated.
Old Nov 1, 2005 | 05:59 PM
It seems Clay Bars are designed to remove containments on the paint including over spray. I bet it cant hurt. I'd pick a low spot and test it before I tried it on a high visibility spot. Let us know how you make out...
Old Nov 1, 2005 | 08:03 PM
ChicagoVtx's Avatar
You may want to post this question to the people at Detailcity or autopia.org here are the links.
http://autopia.org/
http://www.detailcity.com/
Old Nov 2, 2005 | 11:11 AM
Aero Blue's Avatar
Lightbulb Re: I'm on the clay bar bandwagon
This something that the pros need to take care of, wet sanding by a pro can fix this problem. Once you get it back and they tell you when its ok to rub on it, then go ahead and detail the heck out of it. I'd clay and 3 step it once its ok to do so!
Old Jan 23, 2006 | 02:44 PM
bobs's Avatar
Thumbs up Re: I'm on the clay bar bandwagon
I bought the Mother's clay bar kit and all I can say is WOW! I have never seen a shine like that! I tried a little spot on the back fender while I was taking my lunch break and I think I'm going to call in sick for the rest of the day so I can finish the job.
Old Aug 6, 2006 | 11:01 PM
midnightman's Avatar
Add one more to the clay bar list. I too, used the Mother's kit.
I never used a clay bar before but after reading all the raves, I had to try it for myself and I must say, I'm very impressed. The car is smooth as silk and it wasn't nearly as difficult as I thought it would be.
I just wish it could have gotten rid of the acid rain marks. They are only visible from the right angles, but I know they're there.
Old Aug 7, 2006 | 10:23 AM
Aero Blue's Avatar
Welcome aboard MidnightMan and remember, you can use any quick detailer for the lube needed to clay and I'd suggest buying it in bulk as you can use it for clay lube as well as wiping your car down for a quick shine. Just another little tip, cut the clay into about 3 pieces because if you drop it your not going to want to use it again as it hit the ground and it would be too time consuming to try and cut off the contaminated area. You should be able to clay about 4-5 times per pieces. Well, depending on how bad your car gets and that varies with where you live, what's in the air and how often you wash/maintain your ride. BTW, what wax/sealant did you apply afterwards.
Old Aug 7, 2006 | 10:37 AM
I used the carnauba wax that came with the Mother's clay kit. I'll probably follow it up with another coat of NXT in a week or two.
Old Aug 7, 2006 | 07:29 PM
Aero Blue's Avatar
Talking Re: I'm on the clay bar bandwagon
Its cool that they give you something to follow up the clay bar with. The NXT is a good synthetic to use because of the shine it produces and its ease of use, its just that it doesn't last as long. If you car is garage kept you should only have to clay about twice a year, but if it sits outside alot, I'd be lookin' to clay twice that many times. As soon as you fee a fair amount of "grit", pull that bar out and get busy.
Old Aug 7, 2006 | 08:19 PM
Garage kept!
Old Aug 12, 2006 | 12:35 PM
PAULW's Avatar
I got up this morning to wash and try the clay, well I did not think it would make much difference on my garage kept over washed weekend love affair but I'm still chewin those words. I am convinced.
Roty135
17
Oct 11, 2018 10:11 AM
velociabstract
16
Oct 12, 2015 10:56 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
velociabstract
Aug 7, 2015 01:30 PM
White
Jul 30, 2015 10:23 AM
