dead battery
Old Jan 28, 2017 | 06:58 AM
  #41 (permalink)
Blueabyss's Avatar
Default Re: dead battery
For the battery going dead all the time..
Chris
Old Jan 28, 2017 | 07:13 AM
  #42 (permalink)
Chris
You will have to connect a multimeter set to the 10 amp scale between the disconnected negative battery cable and the negative battery terminal.
The reading on you car with everrything off and having set for several minutes should be around 30 milliamps, any more and you will need to start plucking fuses from the under hood fuse panel one at a time until you see the reading drop back to 30 ma.
When this happens, you have located the AREA that is drawing the amps.
Go from there to resolve the problem.
Old Jan 28, 2017 | 11:10 PM
  #43 (permalink)
sunsetseeker's Avatar
New member here.... Just purchased a 2005 roadster a few weeks ago. Same problem here. It starts fine every day. Let it sit for two to three days and the battery is dead. Very disturbing. Battery and alternator check out fine. Battery appears to be fairly new. Will try the procedure mentioned above. Love this car!!!
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
