Int lights won't go off and alarm comes on
Old Dec 16, 2009 | 04:36 PM
Wedge's Avatar
Default Int lights won't go off and alarm comes on
I’ve got an SRT6 with some strange goings-on that I think are electric-related which is why I’m posting here.
Recently my dome lights stopped going out when I closed my door. Then the other day, after going off, the lights came back on while driving and wouldn’t go out. And earlier in the day, about 2 hours after parking and locking up, the alarm came on.
I’ve tried opening and closing both doors and rear hatch and I now can’t get the interior lights to go off other than switching them off manually. I’m also concerned about locking the car anymore as I don’t want to **** off the neighbors with the alarm going off in the middle of the night.
Any ideas anyone?
Thanks
Old Dec 17, 2009 | 08:59 AM
Default Re: Int lights won't go off and alarm comes on
Any ideas anyone?
Thanks
This may be two separate problems, and you should not assume they are connected. Assuming they are related may hide the cause of both.
The lights are controlled by the illumination control module, these lights with the switch in the position you have it are controlled with a timer which may be failing.
I have had my alarm go without any reason and I have put it down to accidentally pressing the alarm button. Keep the keys somewhere other than your pocket and see if the alarm goes on again. If it does you know for sure that it wasn't you who caused it.
Old Dec 17, 2009 | 09:10 AM
tighed1's Avatar
Sounds like the door switch is going bad or came loose or whatever.
That would explain the lights not going on or off as expected.
Reference the alarm going off, if the switch were to "close" while the car was locked the alarm would sense the current draw from the light and go into alarm.
That's my guess.
Old Dec 17, 2009 | 01:43 PM
hcarter's Avatar
That's my guess.
My lights also stay on unless I manually turn them off Door light switch ?
Old Dec 17, 2009 | 09:50 PM
Wedge's Avatar
Thanks for the ideas guys
At the time the alarm went off I was about 70 miles from the car so the accidental button push won't apply... THIS time
Is the timer located in the "illumination control module"?
And the "door switch", is it located within the door or the car?
Old Dec 17, 2009 | 11:51 PM
tighed1's Avatar
The door switch is located below the latch striker plate on the car. Next time the light won't go out check to see if your "door ajar" light is on.
Problem could also be with the rear hatch.
Old Dec 18, 2009 | 01:48 AM
Wedge's Avatar
There's a "Door Ajar" light? (gets out manual...hmmm...page 5... well I'll be...) I've often wondered why this great car didn't have one of those, but they do! Mine has never come on, even when I've tested for it. lol
Old Dec 19, 2009 | 10:53 PM
Wedge's Avatar
New developement; inserting key into drivers side door no longer locks doors. And yes, I turned the key
Something fishy going on here
Old Dec 19, 2009 | 11:52 PM
GDC-SRT's Avatar
I think you just found the culprit.
Try and see if the key will lock the door when it is hanging open.
Sounds like the latch is not making, meaning the light switch will not make.
Just a thought!
Old Dec 20, 2009 | 12:38 AM
MikeR's Avatar
Thanks for all the good info here.... my interior lights on the Aero have not been working in conjunction with the door or hatch. I had to turn the switch off above the mirror. Now I will have to find out which door switch is not working and making the car think the door is always open. (which is kind of stupid when your going down the road at 60mph)
Old Jan 5, 2010 | 10:48 PM
all_Bran's Avatar
Did you ever find the issue? I'm having the same problem here at 11:00pm at night.. wonderful.
pioneer4x4
Jul 1, 2021 10:56 AM
xfClifford
Mar 3, 2021 04:52 PM
pioneer4x4
Mar 25, 2019 10:35 AM
PimpDaddy
Sep 29, 2016 11:55 PM
axnguyen
Jul 21, 2015 11:41 AM
