No Power to radio!
Old Apr 1, 2010 | 09:59 PM
SeansBabyBenz's Avatar
Default No Power to radio!
I cut the factory radio iso connector off then spliced it back correctly, but now apparently the wires are not getting any power. Does anybody know what I can check to figure out what needs to be done. I have found a radio wiring harness that seems like it replaces the whole harness, http://www.cellularaccessory.com/qchbb-mbz.html
I have also found a replacement ISO connector for the Male side (factory side). This would need to be wired into the wires where I originally cut the connector off. VW AUDI INTO FACTORY RADIO*::*HARNESS [REPLACEMENT FOR AFTERMARKET AND FACTORY RADIOS]*::**WIRE HARNESSES*::*Dash Kits Harnesses*::*AUTOTOYS
or
METRA 71-1784 The 71-series harnesses are designed to plug <B>into the factory radio</B> Volkswagen 1987-Up - Into OEM Radio Power and 4-Speaker 16-pin connector HARNESS;
Anybody encountered this problem and figured out whats the best plan to fix it?
Old Apr 9, 2010 | 08:47 PM
aazn's Avatar
Default Re: No Power to radio!
check fuses.
this problem normally happens when yor shot out the wires and a fuse goes.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Apr 28, 2016 02:04 AM
Sterling57
Apr 11, 2016 06:11 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
