infinity head unit RCA to amp
Old Jan 11, 2012 | 03:01 PM
AlexRMC92's Avatar
Default infinity head unit RCA to amp
Does the infinity head unit output line level or speaker level? I would imagine line level, why would the head unit need a speaker level amp just to feed another amp. The reason i ask is because i want to tap a second amp into the splice under the pass floor temporarily until i get a new head unit.
Old Jan 17, 2012 | 12:06 PM
AlexRMC92's Avatar
Default Re: infinity head unit RCA to amp
I just wanted to say that after measuring a 60hz sine wave played via cd i found that the head unit would output 5.98v at full volume.
So its safe to assume that it outputs at line level. I taped the factory wiring and ran it to a separate amp and it works great! no distortion.
If you wanted to add subs with the stock head unit all you have to to do is tap the wiring for the input and remote of the stock amp. Make sure your amp can handle 6v pre amp inputs.
usprb1976
Apr 4, 2024 04:57 PM
Sterling57
Apr 11, 2016 06:11 PM
crossfireE
Oct 2, 2015 01:40 AM
RacerXofFL
Sep 15, 2015 05:00 PM
smokey847
Sep 15, 2015 10:47 AM
