Photo Of Skreem Module And Ignition Ring
Old Feb 1, 2012 | 07:56 AM
britishcommando's Avatar
Default Photo Of Skreem Module And Ignition Ring
Guys,
Please could someone post a photograph of a skreem module so i can forward onto someone that may have one. I have searched high and low on the net but with no luck...
PLEASE PLEASE help...
Thanks
BC
Old Feb 1, 2012 | 09:40 AM
robby363's Avatar
Default Re: Photo Of Skreem Module And Ignition Ring
I don't have a picture of the skreem but here's where it's located if it's any help.
Old Feb 1, 2012 | 10:08 AM
Cheers for that bud.
Here are the photos that i just got emailed to me from a salvage company that i use.
Old Feb 1, 2012 | 01:19 PM
ChuckNorris's Avatar
I have a skreem module if you need one.
Old Feb 1, 2012 | 01:47 PM
Thanks a lot mate. I would love to take up the offer but apparently I need the whole set up from the same vehicle.
I did have the units in the picture but they were from an auto and mines a manual, so when Chryslers fitted it, the ecu was looking for the in Park mode...:
I have hunted high and low and am really struggling to get these parts (used).
BC
Old Feb 1, 2012 | 08:16 PM
MikeR's Avatar
I think someone is yanking your chain(and ripping you off) ..... you should be able to replace the Skreem module without having to change the ECU....or the ignition ring either.... Rudy or someone else can confirm that.... but I am pretty sure that is correct...
Old Feb 1, 2012 | 09:54 PM
mferreira3417's Avatar
yep you have to leave ign in on position for 3 hours with battery charger hooked up. this is for a used one. have done it and it works
Old Feb 2, 2012 | 02:34 AM
Guys the reason I was looking for the complete unit was because I think the car has been attempted to be started over the dreaded '30' times which is meant to ruin the ECU. However, I was unaware that I could use a skreem only from another vehicle.
The guys at Chrysler are being very helpful but haven't come across this problem before. They are being patient with me and have let me keep my car in their workshop whilst i try and find the parts. But after 3 full days searching breakers etc I'm starting to lose hope.
The problem I'm having is trying to find someone with a manual transmission.
I'm running out of options fast.
BC
Old Feb 2, 2012 | 10:22 AM
a7x6kse6's Avatar
Do you have a spare transponder ring also?
Old Feb 2, 2012 | 01:18 PM
MikeR's Avatar
Contact MrMoPar at The Crossfire Shop.... he should be able to help you......
Old Feb 2, 2012 | 04:51 PM
a7x6kse6's Avatar
Thanks, I will try that.
fastfred
Nov 5, 2018 09:47 AM
ozkancab
Sep 25, 2015 10:55 AM
fastfred
Sep 24, 2015 03:05 PM
waldig
Sep 17, 2015 10:35 AM
BEATv1
Sep 10, 2015 12:58 PM
