Needs ECU and Skreem module ASAP!
Old Feb 6, 2012 | 09:10 AM
britishcommando's Avatar
Default Needs ECU and Skreem module ASAP!
PLease, if anyone is able to help or point me in the right direction to obtain these bits it would be greatly appreciated.
I am really having difficulty sourcing these in USED condition.
I am in the UK.
BC
Old Feb 8, 2012 | 09:04 AM
DTMenace's Avatar
Default Re: Needs ECU and Skreem module ASAP!
I am in the UK.
BC
BC
Click on the link below, this is a forum member that is selling parts from 3 different Crossfires at this time. I'm sure he (Mr MoPar), can help you with your needs.....
Dennis
DTMenace
https://www.crossfireforum.org/forum...5-srt-6-a.html
Old Apr 10, 2013 | 12:59 PM
C9ndl86's Avatar
I'm having the same grief u had mate trying to trace the parts for a manual uk model- how did you resolve the issue?
Old Apr 10, 2013 | 01:25 PM
sk8erjosh09's Avatar
Just curious, why do you need an ECU and SKREEM module?
Old Apr 10, 2013 | 05:42 PM
C9ndl86's Avatar
The immobiliser cuts in and alarm sounds when I'm trying to start the vehicle. Can't get any fault codes as the drb won't let me access the anti theft module(skreem) so I'm guessing the module is faulty as its receiving battery voltage. New module is pricy so only option is to source 2nd hand kit of ecu, skreem module, key and ecu- as module has to be configured to ecu and can only be done so once. Problem is I need a manual module which are rare
Old Apr 10, 2013 | 05:56 PM
What are you using or going to use to program these devices together? If you have star das I think you could run drive authorization after getting your current ECU unlocked from Beckmann, that might work. They take the Immo and virginize it from any keys or VIN etc. When they would go to run or read software from the Immo they could probably tell if something is wrong with that part of the immobilizer at least. Alot cheaper than throwing money and a ton of time out for the SKREEM and ECU and such. If you dont have a way to program everything together (star das) you really couldnt do much anyway. Everything would still need to be tied to the Immobilizer and SKREEM etc...
Old Apr 10, 2013 | 07:15 PM
IBLUBYU's Avatar
C9ndl86 .... Hopefully this linky will send you to a thread I started, that may help you. I know it sounds weird, but may be worth a try. I'm not sure how to do a linky, but search for this thread, if the linky doesn't work ....... Sorry
No locking/unlocking ... cured, but I'm not sure why...
Old Apr 10, 2013 | 09:20 PM
rcompart's Avatar
He doesn't need an unlocked ECU, he needs to replace the component that isn't letting drive authorization happen. Not trying to sound rude but there is a lot more to this than just plugging in an SDS and unless you really truly do know what is going on, you should refrain from giving advice because if you give someone the wrong advice, it'll cost them more in the long run. In his case, it may prove to be a cheaper route to replace all the components from a salvage car than buy a SKREEM and find out later that the reason it wasn't communicating was because the PSE took a dirt nap and was putting crap into the datastream which will essentially cause the same communication issues and that is a considerably more expensive module to replace than the SKREEM.
Good luck and take care
Old Apr 11, 2013 | 04:31 AM
C9ndl86's Avatar
I'm in Scotland and have access to the drb3 tool, don't know how the uk model differs from the us! Ive contacted locksmiths for info- what I really need is a company who could inspect repair my faulty skreem- but they only seem interested in ecu repairs. To be honest the cost of a 2nd hand kit and the skreem from merc(same part number) are the same whereas the skreem from Chrysler is £1056 plus vat!!!!
Old Apr 11, 2013 | 10:17 AM
Rudy, this is why I was using might's and maybe's...
Steven 4190
Nov 25, 2015 10:12 AM
RacerXofFL
Sep 15, 2015 05:00 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
Xfirenewbie
U.K.
Aug 13, 2015 04:39 PM
da pink
Aug 12, 2015 05:20 PM
