Annoying issue: Car doesn't always recognize key fob.
Old Feb 11, 2013 | 03:57 PM
Indelibility's Avatar
Default Annoying issue: Car doesn't always recognize key fob.
Not all the time, but about once a week I'll walk to my car, press the unlock button, and nothing. This happens on a weekly basis for reasons I can't figure out. So I have to manually unlock the door, start the car and let the system recognize the key fob again. I've tried a search but nothing came up. The batteries are fresh, so that's not it, and the key fob is tight, so I doubt the batteries are loose in there.
What could be the issue?
Old Feb 11, 2013 | 04:07 PM
rayth's Avatar
Default Re: Annoying issue: Car doesn't always recognize key fob.
when you say "recognize" you mean you do this https://www.crossfireforum.org/forum...key-save.html?
Old Feb 11, 2013 | 04:43 PM
Maybe the car is suffering from early onset dementia in the BCM. Pin a picture of the fob on the mirror, that helps prevent the out of sight out of mind syndrome.
Do you have water in the trunk?
Old Feb 11, 2013 | 04:52 PM
NeedsWings's Avatar
have you tried another set of batteries to make sure the "fresh" ones you picked up are good?
the reason i ask is that there are a lot of china knock off batteries floating around on ebay. if ya got it from a local reputable store then i wouldnt be as suspect. we have them too but unless you wanted soemthing else in the box the shipping sometimes outweighes the price of the batteries.
Old Feb 11, 2013 | 07:09 PM
rcompart's Avatar
What you're describing sounds like the battery contact solder joint to the rest of the board is failing. The next time you have the issue, press and hold the button while looking in the "IR" window to see if you see a little red led flash. If not and it has new batteries, chances are good that's the issue. The bad news is you can't fix it without cracking open the fob but the good news is it's a great chance to fix everything if the fob is worn out.
Take care
Old Feb 11, 2013 | 09:26 PM
Fresh batteries from Target, so nothing from eBay. Guess ill use my other fob for a week and see if the issues till happens.
Old Feb 11, 2013 | 10:58 PM
That would be smart.
mhajek18
Dec 30, 2015 03:40 PM
Keepmeinmind13
Jul 10, 2015 01:05 AM
TropiGal
Jun 25, 2015 08:45 AM
gobraves423
Jun 6, 2015 07:03 PM
WindRestrictor
Jun 1, 2015 02:31 PM
