LED Door Projectors
Old Aug 25, 2014 | 08:04 PM
BMass's Avatar
Default LED Door Projectors
Has anyone ever installed or used LED Door Projectors or LED Ghost Shadow Lights before? They are the lights that once you open your door, the light projects an emblem or logo on the ground. Because I have recently purchased a set of LED Door Projectors. They were supposed to come with an install guide. Well the install guide is vague and pretty much garbage. The install guide is literally on the back of the box and reads as follows...
Step One: Remove the Door Panel
-Snap off the panel located on inside of the door
Step Two: Use the Hole Saw
-Drill out correct size hole fro projector light
Step Three: Wiring to Power
-Connect red and black wires to ground and power
Which sound very simple but are also very vague. There is no actual guide that walks you through the instillation process, especially with hooking the wiring up. To be completely honest I have no idea where to begin with wiring these lights. I had a couple thoughts about wiring them to the lower interior door lights on the door, but have no idea about the ground. Like, if I could just wire the ground to a metal part of the door. Kind of like when hooking up an amp for subwoofers. Like I said though I'm completely clueless. So any and help would be much appreciated along with any diagrams of what the door would look like with the panel removed or anything along those lines. I just don't want to do anything that would fry my electrical system or catch my doors on fire.
PS: Sorry if there is a thread addressing this issue, I couldn't find one.
Old Aug 25, 2014 | 09:46 PM
SNAKEWOLF's Avatar
Default Re: LED Door Projectors
Look on utube under door ghost or projection lights. I HAVE AND STILL USE THIS TYPE LIGHT.wireing diagram is free in service manual which can be found in list of forums repairs. GOOD LUCK
Old Aug 25, 2014 | 11:02 PM
BMass's Avatar
Default
You were referencing the XF Forum right?
Old Aug 26, 2014 | 02:38 AM
Adrian_X's Avatar
I will never use a emblem LED projector that wants me to CUT into the door sheetmetal. Nope, not interested in more rust prone areas lol.
My car is a daily driver, so the salt on the streets of Chicago is enough for me to not want any bare sheet metal.
Old Aug 26, 2014 | 09:53 AM
BMass's Avatar
Default
Originally Posted by Adrian_X
I will never use a emblem LED projector that wants me to CUT into the door sheetmetal. Nope, not interested in more rust prone areas lol. My car is a daily driver, so the salt on the streets of Chicago is enough for me to not want any bare sheet metal.
You're not drilling into any part of the door frame, it's into the plastic of the door panel. At least that's what I'm getting from the install videos.
Old Aug 26, 2014 | 10:01 AM
The are already 4 1.25" or so holes in the metal part of each door plugged with plastic plugs, 2 at the front and 2 at the back.
Old Aug 26, 2014 | 10:51 PM
BMass's Avatar
Default
Really? I never noticed there were holes under the XF doors. I haven't had much time the past couple days to look into getting these installed.
Old Aug 27, 2014 | 01:10 AM
Adrian_X's Avatar
Or you know, this could also be an option? lol
http://www.ebay.com/itm/Car-Logo-LED-Shadow-Laser-Projector-Welcome-Ghost-Door-Step-Lights-For-Chrysler-/310728746158?pt=Motors_Car_Truck_Parts_Accessories&hash=item4858e064ae&vxp=mtr
Old May 17, 2017 | 11:53 AM
mduchoss's Avatar
https://www.crossfireforum.org/forum...rojectors.html
Did you figure out how to install?
Also, which LED projectors are you using? Using the chrysler or mercedes logo?
Thanks,
mduchossois@gmail.com
Old May 20, 2017 | 12:06 PM
Thanks,
This is a three year old thread and the OP has not posted in over two years, maybe you are wasting your time.
Lights to show the ground at night are cool but logos are a bit ricer don't you think.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Billy22Bob
Sep 28, 2015 08:08 PM
AlbertFattal
Sep 24, 2015 05:03 AM
jaesa
Sep 7, 2015 01:50 PM
