Kenwood KMR-D562BT Owners - Volume ???
Has anybody tried a Kenwood KMM-BT515HD yet? Thats what I'm looking at currently.
I don't see why the install wouldn't be very similar to the D562BT. I'll be adding the SiriusXM tuner also.
Looks like what happened the author of the Install pdf:
I settled on the Kenwood KMR-D562BT. Advisor suggested that i use Metra 70-1786 and a Scosche SLC4 Line Output Converter to connect to the amp. He said the volume would be too low without the Line converter
Looks like using the pre-outs shouldn't always be the default choice.
"Dubious to the advice I also ordered a Scosche VW01B harness...I decided to start with the direct wire method using the VW01B to speaker outputs....Short answer is: direct wire works perfectly."
You have to read the whole document, as it clearly states in the next few sentences:
You did a good job and you should get a bonus from Kenwood for the boost in sales you gave them.
Are you and Greg Work referring to me at the moment?
ardenian
Feb 22, 2016 04:34 AM
amx1397
Feb 21, 2016 11:59 AM
